Hello guys,
This is my first post on tek syndicate :).
I hope you can help me with this problem.
So, I bought BF4, downloaded it and played it but I'm not very happy with the performance.
I see guys on youtube and all over the net that play on ultra with the same system but with MUCH higher framerate then I have.
FX 8350, 8GB @1600, HD 7970 (1000/1400MHz).
I have to put my settings on low and still I'm getting lower fps then the guys on the internet, and they have it on ultra.
I have a 1080p screen but so do they and I get 40 to 50 on LOW and they get 50-60 on ULTRA, when I put it on Ultra I get 25 to 30 FPS even when nothing is happening. I might know the problem but I'm not sure. I made this screenshot just after I shut down BF4: http://i814.photobucket.com/albums/zz62/jaronvankooy/ding_zpsafe11d8b.jpg
I see that my GPU usage is almost always 100%, is this normal?
Yes, I have the latest drivers: AMD CC 13.11 Beta8 and .net framework 4.5 and I've done the AMD hotfix but nothing seems to see working.
I hope you guys understand the problem I have.
Thanks in advance!
-Jaron
(sorry if my English is bad, it's because I'm Dutch)
Hmm, the spacebar doesn't seems to be working -.-
You must have some background process running that is affecting your system. Could be some malevolent virus of some sort or maybe you just have another program running. As for the non-functioning spacebar it could just be a coincidence or possibly from the virus rendering your system useless. (yes, without being able to run BF4, your computer is useless 0.0)
But seriously, you may need to completely reinstall Windows. I am sure there are other ways to get rid of the virus without completely getting rid of everything, but in years of computer troubleshooting I've yet to find something that works very well. Try Malewarebytes anti-malware and see what you get. Perhaps it may solve your problem.
My spacebar is working again, I pulled the cable out with my foot -.-.
Wow, a virus you say? I've always been so safe with downloading stuff. Yes have some programs running at the background: Skype, Origin, Steam and the browser (but you need that one because you can't play BF4 online if you have your browser closed). Aren't there other things that cause high GPU usage, faulty hardware maybe (I really hope that isn't the case). I already have AVG, but I will download that Malwarebytes and scan my HDD. If I really need to than I will reinstall windows, I still have the cd I think :/
The drivers might have gone bonkers; uninstall them with This (warning: dont use this on windows 8) And then reinstall the beta 8.
See if the problems persist after this (don't go reinstalling windows just yet :) )
I already reinstalled the drivers and I can't go to the website because I'm not authorized but I filled the fields in correctly, I checked three times and I'm Administrator. But, as I said I already reinstalled them cleanly, so I think the drivers aren't the problem.
okay, what is your cpu usage when idle, and what is it during the gameplay?
What is your motherboard and at what speed is your 8350 clocked at?
Do you have multiple gfx card ocing software installed?
I once had radeon pro installed at the same time as some other oc'ing software (cant remember the name) and it really killed my performance.
After ditching that and just sticking with radeon pro things went back to normal.
i dont know if this is helpful to you, i just downloaded BF4 and installed et, and testing frame rates with Fraps. i have to mention that i only have 1680 x1050P monitor, so its not totaly compairable, but this could be maybe helpful.
- Sys specs:
- FX8350 stock 4.2 GHZ turbo enabled/
- HiS Radeon 7870 GHZ edition
- Samsung syncmaster 1680 x 1050p
- 2x8GB 1600mhz ram.
- BF4 on High settings 1680x1050p ive got arround 74/80 fps.
- BF 4 on ultra settings 1680 x 1050p ive got a steady 45 to 55 FPS.
on 1080p thease scoring will offcourse a bit lower, but i think it will be still playable. if i look at your fps, there must be something wrong somewhere. i think its the driver. because you reach 50fps on low at 1080p thats not good.
p.s my FX8350 reach 51 degrees on stock cooler. but my room temp is 25+
I can run at 1080p medium pretty well with my 7790 and 3870k.People i know who updated there drivers said it helped alot thats all i can think of really, fps should be improved with future updates aswell.
yes indeed like i said i can run the game very smoothly on high at my 7870 ghz edition, on 1050p, but also at Ultra its realy smooth. offcourse its not 1080p, so the numbers on that will be a bit lower but it think it still smoothly playable on high on my 7870 at 1080p
Yeah it should be, a couple of people i know have the 7950 and they are running 1080p ultra pretty well as far as i know so it should be the drivers
@Egnappahz: CPU idle: http://i814.photobucket.com/albums/zz62/jaronvankooy/ding2_zpsb530cecf.jpg
CPU while gaming @random moment: http://i814.photobucket.com/albums/zz62/jaronvankooy/ding3_zps09cfb426.jpg
Motherboard: Asrock 970Extrmeme 3 and my FX 8350 is @stock so 4ghz
@flazza: I think you're right, I had the AMD Catalyst Control Center Overdrive function enabled and I had MSI Afterburner enabled so I deleted MSI Afterburner, still have to test if it worked.
@MisteryAngel Your right, I should have a higher performance then you have but I don't, I just played the game on ultra, it's ok if I look at the wall or the down on the ground, then I have 60 fps but when I look up it goes down to ~30/~40. So something is wrong I think. My temps are all good.
I dont know what it could be i know that lots of people are having issues
p.s add me on origin i need more people to play with, LukeFrewin1998
Update your video card drivers to the beta ones. I had the same problem. Once i did this i have smooth game play.
yeah that should work.
Well i realy not hoping that your motherboard is throttling your CPU, the Asrock 970 Extreme 3 with only 4+1 powerphase and analog vrm, with an FX8350 is not realy a good combination. i did not read it earlier, that have this cpu/mobo combo... this could be an issue!!!!
As I said, I have AMD Catalyst 13.11 beta8. That's the latest driver so far.
@MisteryAngel: This makes no sense to me because the Asrock 970extreme3 was one of the most chosen Motherboards for the FX 8350.
Aaah, I see.
The Asrock does have CPU Throttling problems.
I saw a guy having a Asrock 970Extreme 3 with a FX 6100 and the motherboard throttled his CPU.
They said he needed to turn off Cool 'n Quite in your bios. See the link below.
http://www.tomshardware.co.uk/forum/367209-28-6100-throttling
They also said he needed to flash his bios to 1.8 version:
http://www.asrock.com/mb/AMD/970%20Extreme3/?cat=Download&os=BIOS
Should I do this?
Overclock your CPU and GPU, I use Asus GPU Tweak because it allows me to increase voltage. Then try lowering antialiasing in Battlefield's video settings, this game is demanding.
