Today I got my new HD 7870 from MSI, installed into my pc no problems so far. I installed the drivers for the card etc. So I thought after installing the drivers the resolution would be normal. I checked CCC it said it allready was at the highest resolution (1920x1080p). But my screen still looks like 1280x720p. I tried to fix it by tweaking some things in CCC but that didn't work.
Does anybody know how to fix this?
pss.. sorry for my bad English it's my second language.
So if you right click on ccc and put your pointer on your graphics card It brings up another pop up that says set desktop area to and it list options for resolutions.
Control panel then click display should bring up a screen that gives you options on sizing, smaller medium and larger. correction hardware and sound then display
