which is the better gpu im thinking the 7850 but i see alot of people with the 570 streaming and i like to stream alot
The 7850 draws less power and runs cooler. Plus its on the 28nm manufacturing process.
They are both pretty much the same I think the 570 is slightly faster but the 7850 has more ram so its better future proof.
the cards are pretty close in performance BUT..
with the 7850 you get
more RAM
PCI-E 3.0 (if you use it)
better efficiency (power per watt)
and 28nm process
But if you're getting a 7850 might aswell get a 7870 for a tiny bit more
7850, havent you seen logan OC this? thing over clocks like a beast.
