HBA temperature monitoring
Hi guys
I’m going to start of by saying: “I’m an idiot and i do not, for the life of me, know what im doing.” Not really at least. And the basically equates to me leaning heavily on LLMS and google to figure shit out. Which goes alright for the most part and horribly wrong in other cases.
Long story short, because my zfs pool was corrupting (reading would make stuff dissappear) I got a HBA which appearantly comes from or is meant for a rackserver from amazon. It at some point sent a msg of sorts that it was 107 C which i thought wasnt very good so i ended up putting some fans in my chassis I had laying around before proceeding to rebuild my proxmox single machine multiple vms setup.
Now, I and by extentions a plethora of different chatbots, cannot for the life of me find the temperature reading of said HBA. Which should be there. We’ve tried monitoring the kernel and some tools like storcli and mpt3sas and just regular old hwmon. Which is probably a good thing because it probably means it’s (kinda) fine but i can’t shake this feeling of uneasyness.
SAS9300-16i board_assembly: 03-25600-01B board_tracer: SP74401779 version_product: LSISAS3008 version_fw: 16.00.14.00 version_mpi: 205.32 version_bios: 08.15.00.00 version_nvdata_default: 0e013028h version_nvdata_persistent: 0e013028h BRM_status: active_mode: Initiator supported_mode: Initiator drv_support_bitmap: 0x00000003
===== PCI =====
Region 0: I/O ports at f000 [size=256] Region 1: Memory at 840000000 (64-bit, non-prefetchable) [size=64K] Capabilities: [50] Power Management version 3 ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 0W EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
===== HBA PHY INFO =====
truenas_admin@truenas[~]$ sudo smartctl -x /dev/sdb | grep -iE “temperature|sas|scsi|phy|enclosure”
Sector Sizes: 512 bytes logical, 4096 bytes physical Write SCT (Get) Feature Control Command failed: scsi error aborted command 190 Airflow_Temperature_Cel -O—K 062 049 040 - 38 (Min/Max 38/44) 194 Temperature_Celsius -O—K 038 051 000 - 38 (0 20 0 0 0) 0x11 GPL R/O 1 SATA Phy Event Counters log Current Temperature: 38 Celsius Power Cycle Min/Max Temperature: 38/44 Celsius Lifetime Min/Max Temperature: 20/51 Celsius Under/Over Temperature Limit Count: 0/8 SCT Temperature History Version: 2 Temperature Sampling Period: 3 minutes Temperature Logging Interval: 59 minutes Min/Max recommended Temperature: 10/40 Celsius Min/Max Temperature Limit: 5/60 Celsius Temperature History Size (Index): 128 (5) Index Estimated Time Temperature Celsius 0x05
===== = = === == Temperature Statistics (rev 1) ==
0x05 0x008 1 38 — Current Temperature 0x05 0x010 1 40 — Average Short Term Temperature 0x05 0x018 1 40 — Average Long Term Temperature 0x05 0x020 1 51 — Highest Temperature 0x05 0x028 1 26 — Lowest Temperature 0x05 0x030 1 46 — Highest Average Short Term Temperature 0x05 0x038 1 28 — Lowest Average Short Term Temperature 0x05 0x040 1 40 — Highest Average Long Term Temperature 0x05 0x048 1 31 — Lowest Average Long Term Temperature 0x05 0x050 4 0 — Time in Over-Temperature 0x05 0x058 1 60 — Specified Maximum Operating Temperature 0x05 0x060 4 0 — Time in Under-Temperature 0x05 0x068 1 5 — Specified Minimum Operating Temperature SATA Phy Event Counters (GP Log 0x11)
