HBA Recommendation for Proxmox + TrueNAS
I would like to replace my TrueNAS server with a Proxmox server + virtualized TrueNAS. For this reason, I am looking for a good PCIe HBA to easily allow TrueNAS full access to the connected drives.
What should I consider? Are there any major pitfalls?
I am currently considering a Broadcom 9500 16i HBA. It would work perfectly for my maximum of 16 drives. Is it a good unit and is the $300 price reasonable?
Should I spend that much for my home lab server or are there similarly good and cheaper alternatives?
What kind of drives are you going to be using? Are they all spinning rust drives, ssd or a mix? If you’re only using spinning rust then you might be better off with a LSI 9201 or 9300 if you are trying to save some monies.
Thanks for your answer!
My setup currently includes 8 HDDs, but the rest may become SSD. Where do the price differences come from? Is it just speed?
Anything 9305 or higher is fine really. Even branded stuff like a lenovo 530 or 430 would all be fine. Whatever you find the best deal on of at least the 9305 or higher chipset card. LSI, AVAGO, Broadcom are all the same. Or Dell, or Lenovo rebrands.
A quick browse found this
In the midst of rebuilding my server and did just this using an LSI 9201-16E
the 9200 and even older stuff is still mostly supported. the 9305 and up actually has a good power saving and PCIE feature set that usually makes the extra cost worthwhile.
but yeah nothing wrong with the previous stuff too still.
@Zedicus pretty much nailed it. Just keep in mind that whatever card you get you’ll have to keep it cool somehow.
I can get a new Broadcome 9500-16i for only $100 USD more ($250). Is the price increase worth it?
Whats ‘worth it’ is kinda up to you.
Price is always relative. I understand that part. However, Ebay does not work in my region. Also, I would like to know if there is better reliability etc on newer models or generally new vs used. What are the failure rates of common HBAs? Do they work forever or is it like a consumer SSD that dies after a few cycles?
there is no data cycles on an HBA as there is no storage on the HBA. an HBA is just an interconnect to other devices.
the 9300 series is where PCIE Gen 3 starts being used. The 9305 is the oldest series where a 16i card is available due to power requirements. (technically there is a 9300-16i but just pretend there is not, you do not want it) the cards will work forever if they are cooled well. the tiny heatsink on all HBAs from any generation was designed to be in a high flow server chassis.
rather looking at new or used markets of any location, you will have to browse through countless pages of vendor and non vendor branded cards as they can have dozens of names. my point was just if you spend time hunting, cheaper is possible. if you are in a hurry, grab the first one that has the features you need.
Thanks for the information. Summary, choose HBA features you need, buy the cheapest one.
Obligatory ServeTheHome article
it is a good read still but when that article came out the 9305 was brand new. we are multiple generations past that now, all with BSD and Linux support. and lower power.
