Introduction
I just started a new job at a local ISP. My workflow involves a lot of typing and opening & closing a lot of browser tabs throughout the day. For the first two weeks of the job, I've been using Gnome as my desktop environment, but I would like to switch to either i3 or Sway for more efficiency. I find myself manually tiling windows with the mouse and this is time consuming when done every 30 seconds.
I’ve spent a little bit of time with both i3 and Sway, but I’ve had issues setting them up. I can’t switch my DE at work until I have a 100% stable and reliable experience.
What I Need
I would like to build the i3/Sway on top of Fedora Server; so that I can have a consistent desktop experience with no interference from other installed DE’s, such as popup notifications or themes.
Controls for volume and network.
Knowledge on how to configure for multiple monitors.
Screen lock, or at least how to customize i3lock.
urxvt terminal defaults as white, need to change its color theme so it doesn’t blind me.
Issues I've Had
I haven’t found a definitive guide on how to install Wayland or Xserver on a headless Fedora Server. I’ve followed different guides with varying levels of success.
i3 starts with an active terminal open. Quiting the terminal kills i3.
dmenu breaks on Sway, forcing me quit Sway altogether.
Unable to start dnfdragora, complains that it lacks privileges. Even when launching with sudo.
I think that’s all for now.
