Hi All,
I was wondering if anyone has any clue what is going on. Months ago I upgraded my licence to PfSense Plus , but the base system is still showing as 22.01
Is there any way to fix
the upgrade path without reinstalling ? I’ve read a number of forum posts on it and tried adding the different repos , but no luck.
Please see the screenshots below :
If all your configs are working and your sanity demands proper versioning, Why dont you just do an export of your setting and nuke and pave a fresh new pfsense install?
When you go to the registration page in the system menu does it say that you are registered for pfsense plus? I’ve had issues in the past with it becoming deregistered. Some hardware changes or changes to the configuration if running as a VM can cause this.
But it may just be easier to reinstall and load your config at this point, it’s a fairly painless process. Though it would be easier if you could install pfsense plus rather than having to upgrade to it.
