Haswell & DDR3-2133 Incompatibility
I had recently switched from 1600 to 2133 after reading this article:
http://www.corsair.com/en/blog/bf4-loves-high-speed-memory
Now, bear with me, I am still a little lost in the terminology so when I read:
"G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-2133 Memory operating voltage of 1.6V exceeds the Intel Haswell CPU recommended maximum of 1.5V+5% (1.575V). This memory module may run at a reduced clock rate to meet the 1.5V voltage recommendation, or may require running at a voltage greater than the Intel recommended maximum."
...I threw my hands up.
It will be running on a Z87-G45 mobo that can handle up to DDR3-3000. So it definitely has to be an issue with the i5-4670k Haswell, no?
Not just Haswell, but every Intel platform. Running RAM at a higher voltage could damage the memory controller. Though, some people do run 1.65v RAM on Intel platforms, and they have no issues.
You could purchase some 2133 1.5v RAM, or perhaps adjust your current RAM with new timings and lower volts.
However, 2133 is kinda of pointless unless you're running an APU. I don't buy into the Corsair article. Corsair sells RAM, and was simply trying to cash in on the BF4 hype. I haven't seen anything to confirm it, either way.
Personally, I would just send the RAM back to the store. 1600 is sufficient for any game. Usually, the performance difference between 1333 and 2400 isn't really tangible. It's often less than 1% performance difference.
Unless someone has a source confirming Corsair's article?
I know that with the older intel chips that as long as the memory voltage was within 0.5 volts of the cpu voltage then it was fine to run the memory at a higher voltage. Not sure if it's the same with haswell.
It's 5% safety limit on the voltage. Which takes it up to 1.575-1.6, but not 1.65. But as I aforementioned, there are people that run higher volt memory and don't have problems.
I'm just trying to find links that confirm Corsair's results, and I cannot see anything.
Just read the "best solution" on this site. I think he is right . . . i mean it's called Intel® XMP.
Push me
I just run my ripjaws x 2133 at 1866MHz with my 3570k. Better safe than sorry.
As, long as there isn't a great percentage in the chance of harming anything. Ten bucks more seems like the right price.
I run my 1866 Ram at 1.65v and OCed to 2133.
I am on an asrock Extreme 6 with a 4670k.
So yeah.
1.65 is considered 'safe' for ivy bridge, I don't see why this would change much for haswell. I heard Haswell had better IMC's so overclocking might be easier as well.
