basically I installed Ubuntu (ver 18.04) and followed this guide for installing hashcat https://www.alexanderjsingleton.com/infosexy-how-to-use-hashcat-to-crack-passwords-in-ubuntu-18-04/ , except for the SSH and intel openCL parts.
The problem I’m facing is that when i run hashcat using the command in the guide it doesn’t output to a file or show the results in terminal. I’ve tried looking for a solution but nothing worked (I’ve tried adding “–show”, " --potfile-disable" and “–potfile-path”, none work and it doesn’t out output to the potfile).
Does anyone know what the problem is or can help me solve it?
Thank you.
