Has anyone else got vrr/vsync issues when setting the option to always rather then auto
recently i ran into a bug and i dont know the setting option was the direct cause or what
but after some recent updates i noticed that two thing were accruing
with the display setting set at 165hz an adaptive sync set for always for
my build with a 6750xt gpu and a freesync pro aoc 165hz screen ther was a massive
micro stutter when using any app fyi note the massive micro stutter did not happen
when opening or using the apps or when the mouse pointer was over it but when any were
closed the screen an mouse pointer would stutter an lag would appear as if the was
mass fps change an this would not go away to i click on an empty desktop space.
my gpu vram clock would stay stuck at 96mhz regardless of load
(and clicking on an empty desktop space had no effect) turning the screens freesync
option off the back on would for for a few mins but that was it
up-till now using the display setting of adaptive sync set for always did not cause this
does anyone know why this is ?
