—ok, after I wrote this out I realised it’s a bit on the tldr side, so tldr anyone know where I can get the cheapest 8tb+hdd that is new, im looking at 140$, if you want more context, read below for why—
Ok, My 4tb hdd has basically kicked the bucket but does not know it yet
Nothing I do will get it to flag bad sectors and it keeps running into them on the very last bits of the writeable space.
this hdd is mostly a game drive, so I have little issue with it being able to read data and let me play, its why I have been putting this problem off for a while.
I am also encountering another hdd issue, but this is a not enough space one, not a dying hdd one, that has more or less solved itself, if in a bit of a time intensive way.
Now that I know what drive I can focus my attention on, I chose the game drive.
Now, one of my major issues is I’m coming up on running out of space on my mass storage drive too, which, I can possibly extend the life of by parsing files, but I was planning on later this year biting a bullet and getting a 10-12+tb drive, but if I go the game drive, this may push that upgrade back a year.
right now im looking at an external 8tb drive for the game drive, and I want to stop you there before anything else is said, I am fully aware that a ssd is faster, I know a 7200 internal would be faster, I know 5200 are mostly for mass media and that’s it, I personally don’t care, if I run into a game where the loads are unbearable I can put it on my nvme for a few days while I beat it, and move it back to my game drive for when I get that itch to play it again, I am covered on all sides for any downfall of the usb external drive may have.
the reason it’s a 8tb external, i’m able to get it for 140$ from costco, the closest thing to this price I can find online is 190$ for an internal drive.
My main thing I want to know, is there anywhere I may not be looking that I could find a 8tb drive for cheaper, possibly a larger hdd with the same price per gb.
the 8tb drive will hold all the data of the 4tb, around 400gb that never got transfered over for some reason, freeing up main drive space, allowing me to go another year without upgrading, with the only down side being its an external 5200/5900 drive.
