Halo Strix or R9700?
I am not sure I am posting this in the right place.
Looking to run local AI models at a home, mostly to experiment/not get left behind knowledge wise. Unfortunately I don’t make a lot of money in my current role and can’t really afford to take out loans/max out credit cards to buy a Epyc system with 4x R9700s or a cluster of Halo Strix Minisforums.
What is killing me is that last year when the Minisforum was like 2k (Now they are over 4.5k) I felt it was too expensive and I was looking at the r9700s back in July 2026 when they were only 1500 Euro and felt it was so expensive back then, but now they are 2500 euro and going up in a few days.
Based on upon folk’s personal experiences with their home hosting, which would be the more sensible option at this time 1x AI PRO R9700 to put into my old AM4 PC? The issue here being if I want to have a second or more R9700s I will also need to upgrade Motherboard, Processor and PSU.
Or for the sake of having larger, abet slower, memory pool, stretching my finances and investing in a Minisforum MS-S1, with all it’s fast networking / USB 4 v2 ports to perhaps be able to buy another one at some point next year to?
With my limited budget and currently risk aversion mindset, I missed the boat on reasonably priced V100s and other old enterprise hardware. And they don’t come with warranties etc that I really would feel more comfortable having at this point.
Thank you for any input and advice.
If you want token speed, choose the GPU. If you want model size, go Gorgon Halo with 192 GB RAM.
What hardware do you already have? You may not need any new equipment for that specific use; 8-12GB VRAM could load and run 7-9B-class LLMs fine, and even the CPU could run 35B-A3B MoEs at reasonable speed if you have 32GB+ RAM.
The upper limit for a single R9700 at this moment is the Qwen3.8-27B at 5-bit quantization with Radiance. Qwen-Flash-Next would need 64GB of RAM for offloading plus overhead. Strix/Gorgon Halo are not so constrained, but are frankly far too expensive for their compute.
My guess is that AM4 doesn’t support 8x8 splits on the PCIe 16x slots. So you will be 8x and 4x probably? That’s if you have a full 16x slots. Then again one might be PCI-e 3.0… You would need to post the MB brand and model for others to help on that front. Software what are you planning on running will be needed for others to suggest what is best. I currently bought 2x 5060ti 16GB cards and been decent for LM Studio. Qwen 3.8 27b Q4 256k context has been fine. If you want to be SUPER productive I would buy faster hardware. I picked up a 3090 / 3080TI from my cousin and plan on using those for ComfyUI work. I am pondering returning the 5060TI cards and grabbing two 9700 Pro card, just because my coding sessions are not getting shorter as the project grows and 256k can run out quicker than you would think. Short code problems not an issue.
(post deleted by author)
AM4 Does x8/x8 depending on the board and technically there is one board out there that does x8/x8/x8 but the third one is through the chipset and bandwidth limited because of it and possibly the extra latency might give you a problem to plus tp3 isnt really a thing as far as I know. My inference server that I use is a 3900x, 64GB ddr4 3200, 2 R9700s. I use a Q5 quant of qwen flash next and it is genuinly impressive what it can do. Speed wise it can push between 140-200 tokens/s on decode and a couple thousand prefill. I run 2 concurrency at 400k context limit. If you are going for daily usable inference in my experience I think R9700s are the way to go because for local llm intelligence level I personally think speed is more valuable to me than 5% more “intelligence”. I would only go gorgon halo or strix halo if I had a specific model and reason in mind for it.
