Kubuntu 24.04
6.8.0-58-generic
I’m not exactly sure what’s happening, I had a working VFIO setup, passing through my RX6600. Suddenly my VMs stop working, fiddle around with them, turns out my GPU is now hitting me with Code 43.
Using lspci -v I still have the kernel driver in use as vfio-pci
44:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Navi 23 [Radeon RX 6600/6600 XT/6600M] (rev c7) (prog-if 00 [VGA controller])
Subsystem: Tul Corporation / PowerColor Navi 23 [Radeon RX 6600/6600 XT/6600M]
Flags: bus master, fast devsel, latency 0, IRQ 119, IOMMU group 45
Memory at 7a00000000 (64-bit, prefetchable) [size=8G]
Memory at 7c00000000 (64-bit, prefetchable) [size=256M]
I/O ports at e000 [size=256]
Memory at efa00000 (32-bit, non-prefetchable) [size=1M]
Expansion ROM at efb00000 [disabled] [size=128K]
Capabilities: <access denied>
Kernel driver in use: vfio-pci
Kernel modules: amdgpu
44:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Navi 21/23 HDMI/DP Audio Controller
Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] Navi 21/23 HDMI/DP Audio Controller
Flags: bus master, fast devsel, latency 0, IRQ 118, IOMMU group 46
Memory at efb20000 (32-bit, non-prefetchable) [size=16K]
Kernel modules: snd_hda_intel
Are there logs you can check for new packages installed recently?
Did any bios settings change?
No bios changes, when it initially happened, ironically I got a new CPU after I noticed it (upgraded from 3900x → 5900xt) which did cause me to go through my bios settings and check everything.
As for logs about packages, I’m not sure if I can get logs that old, because it happened sometime in the last 3 weeks… if not a little longer…
I have 5 different libvirt configs, all of them with the GPU broke, but here’s one of them
<domain type="kvm">
<name>24Linux</name>
<uuid>c0899859-4668-4e85-a744-3a9590d07139</uuid>
<metadata>
<libosinfo:libosinfo xmlns:libosinfo="http://libosinfo.org/xmlns/libvirt/domain/1.0">
<libosinfo:os id="http://libosinfo.org/linux/2022"/>
</libosinfo:libosinfo>
</metadata>
<memory unit="KiB">8388608</memory>
<currentMemory unit="KiB">8388608</currentMemory>
<vcpu placement="static">8</vcpu>
<os firmware="efi">
<type arch="x86_64" machine="pc-q35-8.2">hvm</type>
<firmware>
<feature enabled="no" name="enrolled-keys"/>
<feature enabled="no" name="secure-boot"/>
</firmware>
<loader readonly="yes" type="pflash">/usr/share/OVMF/OVMF_CODE_4M.fd</loader>
<nvram template="/usr/share/OVMF/OVMF_VARS_4M.fd">/var/lib/libvirt/qemu/nvram/24Linux_VARS.fd</nvram>
<boot dev="hd"/>
</os>
<features>
<acpi/>
<apic/>
<vmport state="off"/>
</features>
<cpu mode="host-passthrough" check="none" migratable="on">
<topology sockets="1" dies="1" cores="2" threads="4"/>
</cpu>
<clock offset="utc">
<timer name="rtc" tickpolicy="catchup"/>
<timer name="pit" tickpolicy="delay"/>
<timer name="hpet" present="no"/>
</clock>
<on_poweroff>destroy</on_poweroff>
<on_reboot>restart</on_reboot>
<on_crash>destroy</on_crash>
<pm>
<suspend-to-mem enabled="no"/>
<suspend-to-disk enabled="no"/>
</pm>
<devices>
<emulator>/usr/bin/qemu-system-x86_64</emulator>
<disk type="file" device="disk">
<driver name="qemu" type="qcow2"/>
<source file="{REDACTED}.qcow2"/>
<target dev="sda" bus="sata"/>
<address type="drive" controller="0" bus="0" target="0" unit="0"/>
</disk>
<controller type="usb" index="0" model="qemu-xhci" ports="15">
<address type="pci" domain="0x0000" bus="0x02" slot="0x00" function="0x0"/>
</controller>
<controller type="pci" index="0" model="pcie-root"/>
<controller type="pci" index="1" model="pcie-root-port">
<model name="pcie-root-port"/>
<target chassis="1" port="0x8"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x0" multifunction="on"/>
</controller>
<controller type="pci" index="2" model="pcie-root-port">
<target chassis="2" port="0x9"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x1"/>
</controller>
<controller type="pci" index="3" model="pcie-root-port">
<target chassis="3" port="0xa"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x2"/>
</controller>
<controller type="pci" index="4" model="pcie-root-port">
<target chassis="4" port="0xb"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x3"/>
</controller>
<controller type="pci" index="5" model="pcie-root-port">
<target chassis="5" port="0xc"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x4"/>
</controller>
<controller type="pci" index="6" model="pcie-root-port">
<target chassis="6" port="0xd"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x5"/>
</controller>
<controller type="pci" index="7" model="pcie-root-port">
<target chassis="7" port="0xe"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x6"/>
</controller>
<controller type="pci" index="8" model="pcie-root-port">
<target chassis="8" port="0xf"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x7"/>
</controller>
<controller type="pci" index="9" model="pcie-root-port">
<target chassis="9" port="0x10"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x0" multifunction="on"/>
</controller>
<controller type="pci" index="10" model="pcie-root-port">
<target chassis="10" port="0x11"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x1"/>
</controller>
<controller type="pci" index="11" model="pcie-root-port">
<target chassis="11" port="0x12"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x2"/>
</controller>
<controller type="pci" index="12" model="pcie-root-port">
<target chassis="12" port="0x13"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x3"/>
</controller>
<controller type="pci" index="13" model="pcie-root-port">
<target chassis="13" port="0x14"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x4"/>
</controller>
<controller type="pci" index="14" model="pcie-root-port">
<target chassis="14" port="0x15"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x5"/>
</controller>
<controller type="scsi" index="0" model="virtio-scsi">
<address type="pci" domain="0x0000" bus="0x03" slot="0x00" function="0x0"/>
</controller>
<controller type="sata" index="0">
<address type="pci" domain="0x0000" bus="0x00" slot="0x1f" function="0x2"/>
</controller>
<controller type="virtio-serial" index="0">
<address type="pci" domain="0x0000" bus="0x04" slot="0x00" function="0x0"/>
</controller>
<interface type="network">
<mac address="52:54:00:f8:c4:bc"/>
<source network="default"/>
<model type="virtio"/>
<address type="pci" domain="0x0000" bus="0x01" slot="0x00" function="0x0"/>
</interface>
<serial type="pty">
<target type="isa-serial" port="0">
<model name="isa-serial"/>
</target>
</serial>
<console type="pty">
<target type="serial" port="0"/>
</console>
<channel type="unix">
<target type="virtio" name="org.qemu.guest_agent.0"/>
<address type="virtio-serial" controller="0" bus="0" port="1"/>
</channel>
<input type="mouse" bus="ps2"/>
<input type="keyboard" bus="ps2"/>
<audio id="1" type="none"/>
<hostdev mode="subsystem" type="pci" managed="yes">
<source>
<address domain="0x0000" bus="0x44" slot="0x00" function="0x0"/>
</source>
<address type="pci" domain="0x0000" bus="0x05" slot="0x00" function="0x0"/>
</hostdev>
<source>
<address domain="0x0000" bus="0x44" slot="0x00" function="0x1"/>
</source>
<address type="pci" domain="0x0000" bus="0x06" slot="0x00" function="0x0"/>
</hostdev>
<source>
<address domain="0x0000" bus="0x04" slot="0x00" function="0x0"/>
</source>
<address type="pci" domain="0x0000" bus="0x09" slot="0x00" function="0x0"/>
</hostdev>
<watchdog model="itco" action="reset"/>
<memballoon model="virtio">
<address type="pci" domain="0x0000" bus="0x07" slot="0x00" function="0x0"/>
</memballoon>
<rng model="virtio">
<backend model="random">/dev/urandom</backend>
<address type="pci" domain="0x0000" bus="0x08" slot="0x00" function="0x0"/>
</rng>
</devices>
</domain>
Appreciate everyone’s help.
I figured it out, it was a cascade of stupidity… I DID manage to change a bios setting, I guess while updating my bios before I got the new processor resizable bar got added as an option, motherboard used to not have it, and it’s up at the top right, it got set to Auto. Thanks @wizarddata for making me triple check.
Now the question is: is it possible to disable resizable bar for only one gpu now that my motherboard has this feature? or is there a way to get VFIO to work while resizable bar is on?
I’m going to say this thread is done, but I have some digging to do.
THANK YOU
Janos
May 1, 2025, 6:23pm
7
Try this
<features>
<acpi/>
<apic/>
<hyperv mode="custom">
<relaxed state="on"/>
<vapic state="on"/>
<spinlocks state="on" retries="8191"/>
<vpindex state="on"/>
<runtime state="on"/>
<synic state="on"/>
<stimer state="on">
<direct state="on"/>
</stimer>
<reset state="on"/>
<vendor_id state="on" value="AuthenticAMD"/>
<frequencies state="on"/>
<reenlightenment state="on"/>
<tlbflush state="on"/>
<ipi state="on"/>
<evmcs state="off"/>
</hyperv>
<kvm>
<hidden state="on"/>
</kvm>
<smm state="on"/>
<ioapic driver="kvm"/>
</features>
<clock offset="localtime">
<timer name="kvmclock" present="no"/>
<timer name="hypervclock" present="yes"/>
<timer name="tsc" present="yes" mode="native"/>
</clock>
Is this a response before I posted that I figured it was resizable bar?
or is this a way to get resizable bar to work?
Janos
May 1, 2025, 8:15pm
9
REBAR works without configuring anything, I just had to activate it in the BIOS, I didn’t change anything in my libvirt.
Edit: I use Kubuntu 25.04.
I think with 24.04 you have to configure REBAR separately, but I can’t say for sure, I’ve only been using it since 25.04
I gave up on multiple things with 24.04, and just upgraded to 25.04, so we’ll give it a go there
