I'm plannig on building this for a friend. She does video editing pretty professionally and wants a system for the home that is cheaper than a mac, and my own personal quota, kicks the mac's @$$. So, I devised a list on pcpartspicker, that was around 1500 USD which is about 300 USD cheaper than she would have spent on a mac.
This list is as follows:
CPU: i7-3930K 6-core 3.2GHz (most likely will be putting forth a bit more of money for the i7-4930K, but feel free to tell me if I should stay with the 3930K)
CPU COOLER: Corsair H100i Liquid cooling system (planning to overclock a ton, especially with the somewhat low stock clock speed)
MOBO: Gigabyte GA-X79S-UP5-WIFI-EATX LGA2011 (On pcpartspicker it says that this board isn't compatible with the 3930K, but it's 2011 socket and fits in my case, it should fit. If it doesn't please tell me why and also if it is compatible with the 4930K as well)
RAM: G.Skill RipJaws 16 Gb (4x4GB) DDR3-1600 (will probably go for DDR4 when it is feleased but for now I chose this. Also the mobo has 8 RAM slots, so it's quad channel that's why I have 4x4)
Storage: Samsung 840 EVO 120gb SSD (She has tons of external drives, so not much space is needed here, maybe I'll get her a 3TB drive for Xmas or something, but she doesn't need it only for putting the OS, and important software, so they boot extremely quickly)
Graphics card: GTX 660 (It's super cheap now for the holidays and she doesn't need a souped up gfx card because most of the load is on the CPU. Will only be used for vfx editing which she needs something)
Wireless Network Adapter: TP-Link TL-WDN4800 802.11a/b/g/n PCI-Express x1 Wi-Fi Adapter (simple, she needs one and I've heard good reviews, plus it's cheap)
Case: Xion XON-980-BK Mid-Tower Case (Looks good, not too badass, somewhat sleek, fits in with a red theme, supports 240 mm liquid cooling and an EATX motherboard even though it's only ATX)
Power Supply: EVGA SuperNOVA 750 watt 80+ gold (It's cheap and gives more than enough power than she needs, room for upgrades)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer (Cheap, standard)
Monitor: Acer G236HLBbd 60Hz 23.0" (1080p, nice looking, thin, decently priced)
Operating system: Will probably be OSX Lion (cheap and effective)
PCPARTSPICKER LINK: http://pcpartpicker.com/user/JoshPapson/saved/2yto
Please tell me if this part list is compatible with the Hackintosh system, meaning if I load Lion today with this build in the correct process it should give me no problems. Thank you for the help, in advance, and putting up with my essay about my choices :-).
-Josh
EDIT: Also, if there is a cheap but good quality sound card that I could include that would be great, I know it's a stretch but try to keep it under $50. Thanks.
