A short guide to installing the Wire secure communication client on Linux
Debian
- Install apt-transport-https to fetch packages over HTTPS
sudo apt install apt-transport-https
- Import the Wire PGP signing key to verify installed packages:
sudo apt-key adv --fetch-keys https://wire-app.wire.com/linux/releases.key
- Add the Wire repo to your Sources list
echo "deb https://wire-app.wire.com/linux/debian stable main" | sudo tee /etc/apt/sources.list.d/wire-desktop.list
- Lastly, update packages list and install Wire for Linux on Ubuntu with this command:
sudo apt update && sudo apt install wire-desktop
Other Distributions (AppImage)
As of now there is now custom RPM repository for other distributions
- As of writing this you can use this command to get the latest AppImage of wire
mkdir ~/bin/wire
wget https://wire-app.wire.com/linux/wire-2.13.2739-x86_64.AppImage -O ~/bin/wire/wire.AppImage
- Make the AppImage executable
chmod a+x ~/bin/wire/wire.AppImage
- Run the application
~/bin/wire/wire.AppImage &
- Manually Add Wire to your launcher menu of choice
Also yes, the numbers all being 1 is a bug. Tagging @wendell
You can find me on wire under @catsay
