As far as I know, AMD do not provide a GUI on Linux for my R9 Fury X/Fury/Nano Cards on Ubuntu 16.04LTS. I have asked when one will be available but I get no answer.
Does anyone know of a good working GUI solution to control and monitor my AMD cards?
Fan speed, GPU and mem clocks, monitor temps, would be good if I could control any other driver settings available from the GUI.
I am trying to move from Windows to Linux.
In Windows, AMD have Adrenaln Driver with Radeon Settings and ReLive Recorder.
In Linux, as far as I know, there is nothing similar to that provided by AMD.
I have tried Radeon Profile see here:
I managed to compile it, but it needs some more work.
It is not reporting GPU utilization, overclocks are applied to both GPU’s on my system, and there are a few other issues.
I think initial Wattman work is being done for the 4.19 kernel, but sadly all cli based. Nothing preventing you from writing your own scripts, but a GUI would be cool.
I will keep watching and when the Kernel is available with the required patch and the Radeon Profile GUI code is modified I will test it and let everyone know here.
Issue with no GPU Utilization report in Radeon Profile summarised here:
AMD has released its 18.30 drivers for Ubuntu, RedHat and CentOS and says it includes some preliminary Wattman functionality via shell script. It appears you need to install it to actually see that script, and I have not done that.
(I installed 18.20 on Ubuntu and it crashed when I installed a mainline kernel, so I’m gonna assume these are keyed to the distros’ official kernel releases. Anyone know how they handle an update of one of those?)
I downloaded those 18.03 drivers to take a look at them whilst I was running Fedora 26 Server - They won’t install in that version of Linux. I just wanted to look and see what the script contained. I have not had time to look at it.
RE: (I installed 18.20 on Ubuntu and it crashed when I installed a mainline kernel, so I’m gonna assume these are keyed to the distros’ official kernel releases. Anyone know how they handle an update of one of those?)
I am running 18.10 Drivers on Ubuntu 16.04LTS. I have run kernel updates and the drivers still worked fine. I have also managed to set up ROCm and Vulkan SDK. It was difficult to get to the point where the 18.10 drivers worked with the ROCM install (it took a couple ROCm updates) and the Vulkan SDK (1 version update) . There were problems in the installation instructions, errors in ROCm and Vulkan SDK files that I had to edit myself and report back to AMD support.
I came to the conclusion that the 18.10 drivers, had not been tested with the specified ROCm, and Vulkan SDK versions in the driver install instructions from AMD and proven to be installing and working together properly by AMD. They keep telling me to go to Github for ROCm or Lunar G to sort out problems or issues with the AMD install instructions.
Once I have finally got it all running I am very reluctant to attempt another Driver update to 18.30. It has been like wading through treacle just to get it all set up and working.
I think I will purchase a new hard drive, and do a fresh install of Ubuntu 18.04 and try the 18.30 drivers on that. I will let you know what I find. At first guess they have probably installed a script which wraps around the rocm-smi utility, I have used that, it can be used to set fan speeds, clock states etc.
Are you familiar with rocm-smi?
If not I will point you to the documentation.
