Oh right thanks a lot bchampion I honestly thought the 3D pulled from the graphics card. In that case would it be better to get the 3770k with the saving or would the i5 still be fine?
I just bough a 4GB just coz you never know, for example you win a high res monitor or find a boat load of cash in a wallet but mainly because I managed to find one cheaper than a 2gb card
i've got my eye out with the January sales and such so if I can find the 4GB obviously no brainer this is assuming i can't because i've suddenly got a tighter budget
The extra power used for 3D gaming does come from your graphics card (not the memory of the graphics card) and will almost halve your framrates. It's just remdering twice the amount of images than normal 2D, one from a slightly different viewpoint to get a different effect. As long as your monitor is 3D compatible, you wont need to upgrade the CPU
