TL;DR: Need a GFX card for 1080P around $230-250, considering R9 380 4GB, want input on which exact one. Want a card that will support future benefits of DX12-programmed games. nVidia/AMD, as long as return/customer support is good in case I have to return it.
Hey everyone. I just made an account for this forum, although I have been meaning to make one for a long time. I love the show, and I'm sure we all have that in common. I am considering posting my question on Reddit, but sometimes I feel like I know more than most of the people there. This might be because the only hardware discussions I see are in /gaming or something similar. Anyway, here goes:
I am about to buy a graphics card. Finally! I am willing to spend ~$250 USD, and I have been eyeing the 4GB R9 380. I am a bit fuzzy on some things though; I haven't been keeping up too much with graphics hardware. Unless I am mistaken, I remember memory bandwidth being pretty much the most important aspect, and a pretty damn good indicator of overall performance. Recently, with the Fury especially, I learned that this isn't as deterministic as I thought. I hope some of you can help me make a decision, and also to learn a bit more than I know. I have been reading a lot lately and comparing cards, but I want to make this order tomorrow before shipping time. At the same time, I don't want to make the same mistake I have before when I bought a Zotac 560ti 448 too-largely on the way it looks and not enough based on reviews. That card ran insanely hot and died too early - it also had a unique board design that didn't allow for any aftermarket coolers. What a shame! It lasted years, but I have been using a 9800GT EE with a CPU fan rubber-banded onto it for nearly a year now.
Here are some of the things I am looking for:
Adequate / Great cooling (Very Important)
Low heat output if possible, 560 baked my room. (Not too important, I will suffer for performance)
Sturdy design
Possibility to replace the HSF with a common cooling solution, should it die. This isn't too important as long as the fans are good.
Ability to run Fallout 4 and GTA 5 @ 1080P. (I feel silly listing this for some reason.)
Full compatibility and ability to take advantage of DirectX 12 efficiency benefits, if this is possible to determine yet. (It won't be really available until new games are programmed specifically to take advantage of the speed-improving benefits, right?)
I know that 4GB may be overkill for 1080P, but one of the problems I ran in to with my 560Ti 448 was the size of the VRAM. It has 1.25GB, but I quickly used that up with Fallout / Skyrim mods. I also know that a R9 380 should get about 45+FPS on GTAV if the rest of the hardware allows for it.
Current system PCPartpicker with as much as I could find:
http://pcpartpicker.com/p/D3TxMp
The rest of my system is:
Mobo: TH55B HD version 6.xx
CPU: Intel Core i3-540 @ 3.6Ghz ( Dual-core w/ HT - 1st generation, soon to be a i7 860 overclocked. 4/8 C/T)
HSF: Hyper 212
PSU: 550W OCZ ZT Series (Modular, 2x 6-pin PCI-e power cables - 45A on the 12v)
RAM: 7GB 1333Mhz (4GBx1, 1GBx3 - I know this is odd, but just the way I upgraded. Still comes up as dual-channel, must be asymmetric?)
Can anyone give me a review of their R9 380 or comparable card? Can anyone recommend I do or don't get a R9 380 of a specific brand and type? Thank you for reading all of this, or for answering at all.
Edit: I would appreciate any advice in general about this rig / hardware upgrades / websites to shop.
