What should I buy?
Title basically says it all. I have been chasing the GPU passthrough dream for about a year. I have been dissapointed with the performance I have had with my current build and am trying to find out if different/more hardware would solve my issues. So, to give some back-story I will tell you my journey thus far.
Initially/Currently I had/have it set up as follows:
PC Specs
GPUS
Nvidia 970 Host - KDE Neon
Sapphire Fury Guest - Windows 10
CPU
Xeon E3 1230 V5
Mobo
ASUS E3 Pro V5
This setup worked, sort of. However, while I was getting very good fps, I was getting micro-stuttering every 5/10 seconds. The fps wouldnāt drop according to the logs, but you could see a stutter and could hear ever so slight fan revving as well. This made it quite unenjoyable to game with. I tried multiple distros to solve the problems, I tried WINE and all the normalish things to try and solve the problem, but no real luck. I came to two conclusions which I have no real way of testing because I donāt have a plethora of hardware to test with.
A) The ASUS E3 Pro V5 does not support 16x sli/crossfire. When in dual GPU mode the 2nd slot defaults to 4x. I wonder if I was having some kind of bottlenecking here.
B) The Xeon is only a 4 core 8 Hyperthread CPU. When passing 6 threads to the VM it ran much better than with 4 threads, but not perfect, especially in MMO games (specifically GW2) where CPU speed was critical. GW2 was basically unplayable even with 6 threads and a Fury GPU, which seems insane.
Fast forward to today. I have kind of given up on the passthrough. I sold my 2nd gpu and my fury and purchased a 1080. I only run Windows on the machine and only play games on that computer. I use my laptop (an old Lenovo y510p) for linux and use a KVM switch to switch between the machines. This is okay, but I really want to use my desktop horsepower on Linux as I do a fair bit of video editing for my work situations.
So, with that all in mind (I hope someone reads this far, sorry for the life story.) what CPU would you recommend? I have settled with AMD because I really believe that my issue was needing more cpu cores and dual x16 pcie slots. Should I go with a Ryzen 1700/1700x or go whole hog with a TR4 build with a 1920x or 1950x(is that overkill?).
Any and all advice is appreciated. I am currently running Fedora 27 on my laptop, but Iām open to other distros as well. (Also the āduelā booting option sounds interesting.)
Thanks in advance,
Uziah
