GPU Overclocking Problem
Hi I am trying to overclock my GPU but the sliders don't work. Does this mean that i just cant overclock or is there another way. I have moved core clock and memory clock to max but i don't see any diference
Settings > General > unlock voltage control.
...... hang on, a 6570.... voltage no doubt locked as its a really low end card.
yes I  tried unlocking but it does not work, it there any way you can do it in BIOS
your graphics card has too much poverty to overclock.
That card doesn't even have power connecters. The power is provided by the PCIe slot. That's why you can't change the voltage.
