Hi guys, I have this strange issue. I have a xfx 7870 and if I use a 1080p display for a split second at random points lines show on the screen, like when you unplug a cable and the screen shows lines. Straight after it fixes it self, I have tried HDMI dvi and they all do the same thing. Only on a 1080p display, it doesn't happen on a 1600x900 display. I have to use amd CCC scaling option for 1080p. Is there a fix for this? Again it hardly ever happens on full screen games, apart from civ.
Have you downloaded the latest drivers from AMD?
If you have I would suggest that somehow there is an issue with the gpu. It could be that it has become loose in the pcie slot or the power cables have become loose if you have moved your system, double check that these are seated properly. Is your power supply adequate for your system?
My XFX 7870 would show lines on the screen and sometimes recover, while other times it forced the computer to restart. Mine would occur at random times and almost never happened while in a game. I had the problem on a 720p resolution and the majority of the time it would never recover. I ended up having to RMA my card because it was defective, however I would make sure that there are no solutions before resorting to that. The RMA process through XFX was not the easiest, and was quite lengthy. I hope you aren't having the same problem. Best of luck to you.
P.S. Many of the solutions I found while researching at the time of my problem suggested updating drivers or checking my power supply, however they were unsuccessful. If it helps I have a 500w Corsair PSU and I was just fine after receiving a new card.
