So i am looking to get a new GPU. I am going to get a 270x no matter what. problem almost all of the cards are to big. Length and width isnt a problem. its the height. i have a wifi adapter inside of the PCIE x1 slot. and any of the GPU's i want to get cover that slot almost completely.
I have a M5A97 R2.0 mobo, it has two pcie x1 slots and any gpu covers it completely. The measurement between the Pcie x16 slot and the pcie x1 slot is only 38mm. So a Pcie x1 riser wont help. ive been looking and i am having trouble finding any x16 to x1 slots or anyhting like that.
I dont realy get it, the Asus M5A97 R2.0 has 2 pci-e X1 slots. The second one, the closest to the black X4 slot, should be no problem. Unless you gonne get a triple slot GPU.
thats actually my next upgrade to get a wifi-card cause my Gryphon Motherboard doesn't have wi-fi which is mind-boggling to me. i didn't know if 1x cards plugged into a 4x or 8x slot. good to know :)
