I have a GTX 660 that I want to put a new cooler on as the stock one is pretty loud and not massively effective. Can anyone recommend anything to me. Thanks in advance.
You could do custom water cooling but it's expensive or you could get something like this http://www.newegg.com/Product/Product.aspx?Item=N82E16835186052
You would probably be better off just setting the fans to a lower speed using a gpu overclocking tool like msi afterburner or evga precision.
Thanks
I'd rather not use water cooling. Are there any good non water 3rd party cooling solutions? My graphics card is a PNY what software would work with this?
Thanks again
Just because it is a PNY brand GPU does not mean something like MSI afterburner will not work with it. So you can download that or EVGA precision, asus gpu tweak, etc. Basically any program that will overclock an nvidia card. However programs like Sapphire Trixxx or HIS iTurbo won't work because they only make amd cards and therefore only overclock amd cards. I hope that clears things up for you. As for the 3rd party air cooling for a GPU I've never tried any so I don't know really anything about them but if I were you I'd just lower the fan speed and let the GPU run a little hotter for the sake of better acoustics.
I was just given this aftermarket cooler. My friend got a reference 760 and it was getting very hot, so he purchased this Arctic cooler. In the end, however, he ended up returning the reference design card and getting an EVGA w/the ACX cooler, so he gave it to me.
I haven't had a chance to install it on my 7870, but the reviews are pretty good.
Does this mean we will get an update on the performance of this gpu cooler?
Thanks very much
Please let me know how it works out with that
The Prolimatech MK-26 is a better aftermarket cooler than the Accelero. The only problem with it is that it takes up 4 slots with a pair of 120mm/140mm fans on it.
Just installed the cooler today. It doesn't sit as flush to the front of the card as the stock cooler does, so there's a bit of a gap between the front of the card (where the HDMI/DVI ports are) and the front of the cooler. It's not the best looking, but it does seem like it's doing a much better job than stock.
I idle around 32C or so and the highest I've seen so far is around 50C. If it wasn't sticking so far off of the back of the card, I would really like it. I'll keep it on there because it does a better job than stock, but it is kinda ugly.
That sounds good to me. You running at stock clocks?
I have a slight overclock on both the core clock and memory clock, maybe 4-5%. I can't seem to get a significant overclock without some instability, at least when playing BF4.
