GPD Win Max 2 8840u and NVIDIA GPU via OCuLink
Hi,
Has anyone tried connecting an NVIDIA GeForce RTX 3080 using the MinisForum DEG2 dock via OCuLink to a 2024 GPD Win Max 2 with the 8840U processor?
The card works perfectly fine without any issues over TB3/USB4 in a Razer Core X Chroma.
However, there is an issue when using the DEG2.
The card is detected and visible:
lspci | grep -i ‘nvidia’
01:00.0 VGA compatible controller: NVIDIA Corporation GA102 \[GeForce RTX 3080\] (rev a1)
01:00.1 Audio device: NVIDIA Corporation GA102 High Definition Audio Controller (rev a1)
The kernel modules are successfully loaded:
# lsmod | grep -i 'nvidia'
nvidia_drm             94208  13
nvidia_modeset       1552384  19 nvidia_drm
nvidia_uvm           1757184  0
nvidia              62943232  1052 nvidia_uvm,nvidia_modeset
drm_kms_helper        253952  4 drm_display_helper,amdgpu,drm_ttm_helper,nvidia_drm
drm                   765952  27 gpu_sched,i2c_hid,drm_kms_helper,drm_exec,drm_suballoc_helper,drm_display_helper,nvidia,drm_buddy,amdgpu,drm_ttm_helper,nvidia_drm,ttm,amdxcp
video                  81920  2 amdgpu,nvidia_modeset
But whenever I try to run nvidia-smi, I get the following error in dmesg:
kern :warn : [Jul 7 11:53] NVRM: GPU at PCI:0000:01:00: GPU-81d18892-dd0b-6448-db5c-b1497f77ddf4
kern :warn : [ +0,000007] NVRM: Xid (PCI:0000:01:00): 62, pid='<unknown>', name=<unknown>, 00000000 00000000 00000000 00000000 00220030 00300000 00000000 00000000
kern :warn : [ +4,108683] NVRM: GPU 0000:01:00.0: RmInitAdapter failed! (0x26:0x56:1489)
kern :warn : [ +0,000144] NVRM: GPU 0000:01:00.0: rm_init_adapter failed, device minor number 0
…and the process itself fails with a no device found error.
The system I’m using is Debian 12 running kernel 6.12.90 from backports:
# uname -a
Linux Hostname 6.12.90+deb12.1-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.12.90-2~bpo12+1 (2026-05-28) x86_64 GNU/Linux
Installed drivers:
ii  nvidia-driver                                 535.261.03-1                            amd64        NVIDIA metapackage
ii  nvidia-driver-bin                             535.261.03-1                            amd64        NVIDIA driver support binaries
ii  nvidia-driver-libs:amd64                      535.261.03-1                            amd64        NVIDIA metapackage (OpenGL/GLX/EGL/GLES libraries)
ii  nvidia-driver-libs:i386                       535.261.03-1                            i386         NVIDIA metapackage (OpenGL/GLX/EGL/GLES libraries)
I have already tried adding pcie_aspm=off to the kernel boot parameters, as well as adding options nvidia NVreg_EnableGSPFirmware=0 to the kernel module configuration, but neither of those helped.
Also tired to disable ReBAR.
I also search for PCIe speed configuration in the Alt+F5 BIOS menu options in AMD PBS and AMD CBS menus but didn’t find those.
Can anyone help me with it?
I’m using OCuLink cable from the DEG2 set.
