GPD Win 4 2025 - Clean install guide and audio fix
After doing a clean install of Windows in my GPD Win 4 (2025 model). I’ve noticed that I had audio popping issues every now and again. And after updating all the drivers to specific versions, the laptop would crash. I’ve sorted it all out and here’s a quick guide on how to do a clean Windows install, and sort all the audio issues!
  1. Nuke all the partitions and install Windows! By default, Windows 11 Home is bundled with the device, so you can just run the generic installer off the Media Creation Tool and it should work
  2. Download and install the latest drivers from AMD! This should get you up to speed for the most part.
  3. Open Device Manager - For those pesky Unknown drivers, you should download the ones provided by GPD on their support page. And while you’re at it, you may want to grab those DTS:X drivers too!
  4. Right click every Unknown device in Device Driver, select Update Driver, and point the driver search to the unzipped driver folder
If you leave things at this point the device will work, but you will see that there are pops every now and again when you start up the device, and that sometimes you won’t have any audio at all until a random point in time of using the device. If you run into this situation you can do the following:
  1. Download the latest AMD High Definition Audio Controller from Microsoft Update Catalog. Pick the version that is from 2/18/2019 (latest available) and is around 50KB (the 9.6MB ones have compiling and testing information, we don’t need that).
  2. Extract the CAB file with 7zip. You should get an extraction warning that you can dismiss.
  3. Open Device Manager, browse to your Audio inputs and outputs, select the available Speakers and open the menu option View > Devices by connection. You should see something similar to this screenshot.
  4. Right click the highlighted High Definition Audio Controller and select Update driver
  5. Browse to the folder where you extracted the CAB file and let Windows install those drivers
  6. Open the Registry Editor and browse to the key Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\PCI\VEN_1022&DEV_15E3&SUBSYS_########&REV_##\#################\Device Parameters\Interrupt Management\MessageSignaledInterruptProperties. It is important that the device after PCI is called VEN_1022&DEV_15E3
  7. Once there, update the registry key MSISupported to 1
  8. Restart!
Why the last bit? GPD, in their infinite wisdom, has decided to configure the devices in such a way that does not align with a regular clean installation. There are IRQ issues (yes, even to this day) that prevent Windows from detecting new devices (hard crash) and shutting down the computer because of these conflicts. This setting will force the driver to work in a different IRQ, and should resolve all these issues. Was able to find this out from this other forum: System interrupts, Latency, HDaudbus.sys | Sysnative Forums
And that should be it! Enjoy your cleanly wiped GPD Win 4!
PS: Yes I know I can run Steam OS, not doing that right now.
And a forewarning for those that attempt to install Windows 11 25H2 directly! The driver within the image actually causes conflict with this device. You’re going to get random power crashes and USB disconnects! Try to install the driver listed above as quickly as possible to get the system to a stable state.
