What I want to do, is have an automatic update list, that will count how many times everyone appears in the column B ... but all I managed to do was pull up the list of all unique names with =unique(B3:B) ...
Is there a way to make a name automatically join the list, the moment it appears 2 times or more ?
(The count that you see on the right, is me counting manually using Ctrl+C / Ctrl+F / Ctrl+V then removing the ones that appear in the link ...)
Hi. I am not 100% sure what you want it to do or how you want it to work. But as i see it you might be looking for the excel equivalent to the "COUNTIF" function. Hope this helps in any way
What I basically want is to have a list on the side that automatically updates the number of times the names in the B column appear.
So the moment a name appears 2 times, it will be added to the list automatically, with the amount of times it appears within the B column ... is that more "precise" ? And I really have no Excel / Google Docs knowledge, and what I looked up only managed to get me confused xD
Yeah, the third is basically what I want. A list that adds names to it as soon as they appear 2 times or more, and keeps updating the number of times they appear later on.
Could you give me the "code" so I can test it on the Sheet I have ?
Most of the magic happens in column H-L which i have hidden. At the moment the spreadsheet will work down to row 672. If you add more rows than 672 you need to copy the formula in H-J further to the additional rows, edit the formula in K3 and N18.
Note that there might be a bug with the player name <ehab> which seems to have 283 reports and i dont know how to fix it.
