HDD - Seagate Barracuda ST1000DM003 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Motherboard - ASRock 970 PRO3 AM3+ AMD 970 SATA 6Gb AMD Motherboard
GPU - SAPPHIRE Radeon HD 7770 GHz Edition oc GDDR5 PCI Express 3.0 x16 HDCP Ready Video Card
PowerSupply - AZZA Dynamo 850 850W ATX& EPS 12V 2.91 SLI Ready CrossFire Ready Power Supply
Ram - ADATA XPG Gaming Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model AX3U1600GC4G9-2G
CPU - AMD Phenom II X4 965 Black Edition Deneb 3.4GHz Socket AM3 125W Quad-Core Processor HDZ965FBGMBOX
upgrade to either the amd fx 6300 or 4300
Compatibilty issues or just upgrade?
I'd say he means to upgrade. You'd want a mobo with a 990 chipset to make best use of the FX CPUs though. As far as compatibility, I don't see anything wrong with what you have listed.
thenewb
December 29, 2012, 4:08am
#5
please overkill on psu unless your ocing and upgrading to power hungry parts in the next 3 years maybe.
drop that down to 700 watts. it will serve you well
heck even 650 watts would work as well
thenewb
December 29, 2012, 4:09am
#6
and yea like they said upgrade your cpu to an fx version
the phenom is pretty old
i rather stick with current stuff
That's true, I have a 6300 and my 650 watt works fine.
