I have been using Intel P4500 and P4600 U.2 SSD’s for some time now in my home server builds for download drives and write-heavy drives. The long write lifespans on these have been really helpful since I have them being written basically 24/7 for weeks or months at a time.
However I also am using all tower-based systems with consumer motherboards, so I dont have any native U.2 ports, and have been using the M.2 → U.2 adapters, or PCIe to U.2 adapters.
I am getting tired of the extra point of failure these adapters introduce, and the M.2 → U.2 ones especially require extra SATA power cables from the PSU which is becoming an issue as well. So I would like to try to swap these drives for something that is natively in the M.2 form factor that does not need an adapter (I dont have any PCIe slots available anymore…)
But every time I try to search Google or eBay or elsewhere for M.2 SSD’s, I get only listings and information on consumer grade versions. I am having a pretty hard time getting info on available data center and enterprise grade models in the M.2 form factor. The internet is basically just flooded with consumer M.2 SSD stuff. So I was wondering if anyone on here had suggestions of specific models of drives that might be easily available with a write lifespan of 1PBW+++ in a size of about 2TB, give or take a few TB. Suggestions?
I hope you’re hungry, because the MOQ is 10 for this one. They do have larger capacities on the site too if you look around, but that was the one I was interested in when doing my own search last year.
fwiw I dont actually care about speed at all, I am not even close to saturating PCIe 3.0 since my write speeds are limited to my ISP download speeds anyway.
I did notice the Phision Pascari drives pop up in a few searches but had not yet looked into them since they seem pretty unfamiliar and did not have any sort of reviews or details on Newegg. I will look into that more then
I ended up going with the Samsung PM983 2TB version
found a brand new one on eBay for $180 ; lots of used ones available as well for slightly less. Its worked really nicely. Based on the specs of “1.3 DWPD for 3 years” that should mean this 2TB model has roughly 7PBW lifespan. Perfect. So far I am up to 29TB written over two months.
The 22110 M.2 size fits just fine in the M.2 slots on the Asus ROG B550-F motherboard, only caveat being that the mobo’s included M.2 heat spreader does not work since the screw mount for the 22110 size is the same one that would have been used for the heat spreader.
