So im looking for a dac that has a coaxial input so i can hook it up to my blu ray player, i cant really find any trustworthy ones :/
Having a built in amp would be hand but not 100% necessary
Any help is appreciated
Thanks
Do you want it to be decent grade audio gear, or do you just need something that works and is not completely shit?
If you need the latter, then the FiiO Taishan is just what you need.
hmmmm i would prefer something decent but if theres nothing about worth while then thatll be good enough
