Good AM3+ OC Motherboard
Hi does anyone know fo any motherboards that will be good for overclocking my FX 8320, preferably around £80. I will be using it for gaming. Thanks
Jus save up for a little bit more and get the  Gigabyte 990FXA-UD3.
if you really can't wait like mintysyrup suggested this one looks pretty good
http://www.scan.co.uk/products/asrock-970-extreme4-amd-970-s-am3plus-ddr3-2100mhz(oc)-sata-iii-6gb-s-sata-raid-pcie-20-(x16)-atx-us
NO dont go with an Asrock 970 board if you plan to do any overclocking.
Go to look for an Asus M5A97 evo R2.0
of the Gigabyte GA970A-UD3 <-- by this board its inportant before you buy  it,  ask the shop to flash the bios to the latest version. or ask if this board support FX8320 out of box
Asrock 970 boards stink for overclocking! Don't do it!
The ASUS that Mistery recommended is nice, I use one and it has been a dream to work with. It has a 6+2 power phase vs. 4+1 on the Asrock.
I have a Gigabyte 990FXA UD3 rev1.2 with a [email protected] so i sugest that board.
Sorry for my bad Engglish
