Good Air Flow Case
I'm not a fan of the 540 cube cases, they occupy nearly double the width under your desk and have far worse cooling for you HDD's than a regular case, where they would sit directly in front of the intake.
Also the air cooled graphics card and custom loop is a interesting touch, I take it that was temporary?
Op states hes looking for a mid tower people... so I doubt he wants a mATX case or a full-tower.
Anyway I'd go with either the Fractual Design R4 non-windowed as it uses fully 140mm fans with plenty of mounting locations. Its also a fairly well built case and is very quiet, but its not small. I personally own a non-windowed black pearl and run with the top and side covers on, I use a H90 as exhaust in the rear, the 2 factory slient series 3pin fans in the front of the cases running of the inbuilt 3 channel controller and a single Noctua PWM fan in the bottom blowing on the graphics card. It works well, with good temperatures and very low noise.
A option that is both cheaper and smaller is the Corsair 200r. Its not a high end case but its well made, has all the expected features like USB3.0 ports and has a very sensible layout that allows it to fit 3x5.25", 4x3.5" and 4x2.5" drives, fully length graphics cards, decent cable management and good airflow from 4x 140mm and 4x 120mm fans, although personally I'd avoid using the 120mm bottom intake, but 3, 5 and 7 fan configs all make perfect sense. The open top does let you hear you CPU (unless AIO) and graphics card fans a little more than some other cases, but the passive cooling it offers lets you run lower case fan speeds, which does somewhat offset this, particularly if you buy a decent CPU cooler. The open to also allows you to mount 240mm AIO rads like the h100i if you are wanting to overclock. It also has a windowed option if thats your thing, but you loose the 2x140mm side fans. Ultimately I think for the price the 200r is one of the best cases on the market, especially because its design gives it a very small footprint for a mid-tower without really compromising anything. But do keep in mind its not nearly as expensive, large or fancy as the Define R4, so if your looking to build a high end system and have looks and noise as proprieties, the other is a better bet, but this cools well, is built decent, holds a high end system fine and is cheap.
