Good Air Flow Case
Mid tower, I have a full tower. I'm just looking for a good airflow case, I'm putting a tiny graphics card, and 3 drives in it.
Budget??? Bitfenix merc alpha is worth a look, cheap and with the right fans good air flow is a breeze. Or corsair's 350D if your budget permits etc.
The 350D is for mATX motherboards, I doubt the OP has one of those in a full tower. My first suggestion would be the Fractal Design Arc Midi R2, I am sure that are other good choices out there, but this is the first that comes to mind for a reasonably sized mid tower with good air cooling potential. I'll update if I think of another case.
Cooler master has the HAF cases. I own the HAF 922 (which is fucking huge in my opinion, would hate to own a full size) but it does a pretty good job after adding some fans to it.
I have the HAF 932 & it is huge...water cooled cpu with push pull fans + 3 giant fans tuning slow ...fairly quiet
Champ there are plenty of peeps for whatever weird reasons have small boards in full size or bigger cases. I personally don't understand it myself but it happens quite often.
I had a matx in a thermaltake chaser mk-i, because I got the case for 70€ instead of 140, it is a great case and the mb was at 50€ vs 100€ atx one
I know that there are people who use mATX boards in a full tower. I wasn't saying that NOBODY uses an mATX motherboard in a full tower, but in my mind this happens rarely (or less than in 50% of the cases, to be more precise), so from a statistical point of view it made more sense to assume that the OP doesn't have mATX motherboard in a full tower and base my recommendation on that.
Anyway, my recommendation stands. I couldn't think of another case that is better than the Midi R2 in OP's case.
antec lanboy air
its the only modular case i know of
you could mount a shitload of fans on it
https://www.youtube.com/watch?v=649kvK9bN6o
https://www.youtube.com/watch?v=nwGdEkmZn0Q
Corsair Air 540.
I use the AIR540. Its an amazing Case. For Air, and water, If you choose to go liquid later on.
I'm getting a new case, yesterday i put in a preorder for the NZXT H440.  I was torn between it and the Air540.  Anything you could say to boost the 540 over the 440.
Was interested in the Corsair 760t  until I saw the cheap top panel.
I'm using the NZXT Phantom 630 (full tower). Even with the stock fans installed (200mm side intake, 200mm front intake, 200mm top exhaust, 140mm rear exhaust) it has EXCELLENT air flow. The options to mount two 120/140 in the bottom, 120/140 internally, and either 2 - 200mm, 2-140mm, or 2-120mm in the top as well helps a bunch.
Great cable management. All of the cables, PSU, drives, are out of the way to allow for perfect airflow. Nice side panel.
Here's mine. I painted it and added lights.
Its an older photo, it looks a bit different now, but you get the point of it.
OP has a "tiny gpu and 3 drives", he doesnt need much eh. Just sayin'... May help if OP stated his board size as well. As for the lanboy air, if you've ever had the dis-pleasure of building in one or seeing one in the flesh you'd think twice about it.
No cable management, and terribly loud.
yep.
