I impulse bought a supposedly cheap 9734 the other day, already ordered motherboard ( ASRock Rack Server Motherboard BERGAMOD8-2L2T) and memory, I just realized I was missing a cooler but a quick search online didn’t return anything. Noctua and Artic don’t even have models that support it. Can you recommend something?
I’ll use a full tower with plenty of clearance and fans so pretty much anything that fits the socket will do.
No idea how they have 8 DIMMs on that board when the CPU has 12 memory channels and we lost 20-30% CPU benchmark scores not having all channels populated.
yeah, I couldn’t find a single slot 12 DIMM motherboard. In fairness, I didn’t look that hard, I panicked after buying the EPYC so I looked at newegg and a couple other places only and this ASRock looked pretty good although I couldn’t find reviews online. But having watched Wendell’s videos about previous iterations I guessed it was safe enough. We’ll see…
I only bought 4 DIMMS because I have a suspicion that the CPU won’t work, but if it does I’ll get 4 more of the same brand, don’t have the brand handy right now.
maybe as a VM but I want to install Proxmox on it and run in general Linux VMs. Since it has Zen4c cores I don’t think it will be a good workstation anyways
sorry to hear they did not post.
There are other ebay vendor choices and I am glad to point you to the very competitively priced and reputable vendors that exist.
ON HEATSINKKS:
The cool server heatsink, (3 versions) needs to be the one with the full copper plate covering the CPU,
2 out 3 of the ones sold by them do not cover the whole cpu with the transfer plate.
Unfortunately all listed under the same sale items/same picture, but different products.
I ordered 12 to get 4 that were right, and returned , and then had to modify them anyhow.
ALL other air heatsinks are NOT enough, please review this thread to understand more and maybe sone beneficial details,
Get this version ONLY (picture)
the other versions have 30% less cooling fins, and 44% less coverage of the actual cpu heatsink plate
Lastly, the copper plate on the other two versions is 2mm thinner (not as thick)
visually if you go by pics, make sure the radiator is 120mm of fins wide and 120mm of fins long.
lastly the upper cover plate is black steel (not gray aluminum) has no writing on it and is secured by two Torx 15
In case it is helpful to know I have the Cool server cooler (ordered on Ebay - “Cool server cooler for 9654”) on my 9654 Epyc build.
I’m using this thing in my office and it does a really nice job. The CPU maxes out at like 73c and what surprises me the most, it ain’t the loudest machine I own
VRMs on the other hand are slightly too high for my taste, reaching 86c on a hot day. It is a Supermicro motherboard in a desktop case so I guess it shouldn’t surprise me that much.
Wendell did a video about the arctic freezer 4u-sp5. but i have yet to be able to find it anywhere. its not listed any of the places where they say it should be last i looked.
this thread is useful for alternative coolers though. so i guess theres that.
I have several. The fans, new in box, are worthless and have issues, the build quality is suspect on the coolers. Aluminum fins just slide right off the heatpipes,
The heatpipes, and bend area, misses the outer edge of the internal chiplets. as there is no plate, the pipes bend off before the critical contact area is reached
I tried running these for SP5, but a poor product
I tried running the SP3 and also a poor product, so many quality control issues
Advice,
stay away for now an or until they resolve the build quality issues
@JayVenturi is THE guy when it comes to cooling SP5
We still slap Dynatrons onto the 225 watt TDP SKUs we push out for deployments with the fan cranked to max, but for the 400 watt skus, we’ll be following his recommendations.
The coolserver M99 doesn’t seem to exist on their website. On AliExpress, I see M98 that looks almost like yours but doesn’t look like copper on bottom, and M99 but it has two sets of fins and fans, very different… Does anyone have a model number or link to the correct heatsink? Thanks!
