Gigabyte MZ32-AR0 sensor locations
Does anyone know the physical locations of the various temperature sensors on the MZ32-AR0 motherboard? The manual has nothing. There are obvious temperature sensors under each m.2 slot but there’s only one temperature sensor labeled “M2” in the BMC interface.
ipmitool sensors gives the following temperature sensors:
CPU0_TEMP
DIMMG0_TEMP
DIMMG1_TEMP
CPU0_DTS
M2_G0_AMB_TEMP
MB_TEMP1
MB_TEMP2
PSU1_HOTSPOT
PSU2_HOTSPOT
VR_P0_TEMP
VR_DIMMG0_TEMP
VR_DIMMG1_TEMP
CPU0_DTS seems to be CPU0_TEMP subtracted from 100 which is weird. DIMMG0 and DIMMG1 would seem to be the temperature readings of the DIMMs in the G0 and G1 slots, but G0 is not populated, and there aren’t readings from any of the other DIMMs. M2_G0_AMB_TEMP is I assume one of the m.2 sensors but which one, and where’s the other one? And what are MB_TEMP1 and MB_TEMP2 indicating?
Yah I understand the confusion as the manual should have a reference table included for this.
I happen to know some sensors only appear/output values if the slot they represent is populated.
It could explain the missing m.2 sensor, if you didn’t populated the other slot.
Did you check the ipmi web console by any chance?
All sensors should be listed in the web console, even if they are inactive.
Still won’t tell you the locations but it can clear up some of the missing ones.
Also it’s not uncommon the ipmi/bmc doesn’t recognize specific components, or the component itself lacks the required sensor logic.
Again the web console should list if any sensors have a incompatibility.
This is my best guess on the locations.
I’ll use page 5 of the board manual as reference.
M2_G0_AMB_TEMP is bound to slot 1 (Left), and M2_G1 is slot 2 (right)
CPU0_TEMP is pretty self explanatory.
CPU0_DTS is a strange one yes, and your guess is the best I could find myself.
It might do double duty as how much degrees until thermal safety mechanisms triggers.
DIMMG1_TEMP is the temperature of a dedicated ic chip on ram module G1.
You might get a duplicate value on DIMMG0_TEMP as G1 and G0 share a communication bus.
Or a completely random value caused by electrical noise is also not unheard of.
VR_DIMMG1_TEMP is unusual as VR indicates a voltage/power rail.
Usually multiple dimms share a power rail which is also the case on this board.
My best guess judging from the boards physical vrm layout, every memory channel pair has a vrm located directly above the dimm slots.
So VR_DIMMG0_TEMP and VR_DIMMG1_TEMP are probably reporting the same value.
VR_P0_TEMP is the CPU’s dedicated vrm temperature, it’s probably the average as the CPU has 6 or 8 individual rails. They are located in a group of 6 above and group of 2 below the cpu.
MB_TEMP1 and MB_TEMP2 are dedicated sensors to tell the board temperature of a specific location.
It’s common to have those spread around as it identifies heat build up caused by airflow issues, add in cards running hot etc.
As for the locations, your guess is as good as mine.
Logically thinking MB_TEMP1 is located in the bottom area the cpu socket is closest to the ede of the board.
MB_TEMP2 is around the pcie slots, this way the boards can be split horizontal in 2 temperature zones.
It’s also possible they are on the left and right side of the board as to vertically split the zones.
PSU1_HOTSPOT and PSU2_HOTSPOT are not measured by the board.
It’s usually reported by the a power distribution board/unit which is part in a server housing and manages multiple power supplies for redendancy/failover.
Usually power distribution board connects to the motherboard using a pmbus cable and header.
It’s located to the top right just above the 24 pin atx power connector on this board.
Btw if the sensor names don’t make any more sense in the ipmi web console you might want to factory reset or re-flash the bmc.
It’s possible the previous owner disabled individual sensors, or messed with the bmc firmware so resetting/flashing is less work than to track down what’s wrong.
The BMC web console shows the same sensors that ipmitool shows, and this is after a factory reset of the BMC and BIOS. I’ve populated both m.2 slots. The motherboard has a temperature sensor on a flex cable sticking up to contact the bottom side of each m.2 module. The G0 and G1 DIMM temperature readings are different so it’s not a duplicated value. I have DIMMs in A1, B1, C1…H1 (8 DIMMs total) so I’d expect to see 8 DIMM temperature readings. Very little about the sensor names makes sense. I’ve contacted Gigabyte but haven’t gotten any answers back yet.
I might have a suspicion what could be wrong.
It’s possible to flash bios and bmc images from newer boards to older hardware designs to add support for cpu’s the board originally wasn’t compatible with.
Careless flashing firmwares could messes with the bmc and sensors.
It should be easy to check if you can verify some stuff for me.
Just to verify I’m not reading in to stuff, you got the board pre owned/used right?
Where did you get it and do you remember how it was advertised. In specific the CPU series it supported and any mention of a revision (rev) or hardware version.
Could you take a look at the board, it should have some white text in the middle with the model name, next to it some small text telling you if it’s a rev 1 or rev 3 board. What is the number marked on the board?
Also which cpu is currently installed on the board?
Last I need current version numbers you can find in the ipmi web console.
Can you take a look at the current installed bmc firmware version and bios version?
They are usually listed on the main page.
It’s a rev3 board with an Epyc 7443 (Milan). BMC is 12.61.39, BIOS is M32.
Well this clears up about all suspicions I had.
Same goes for my ideas unfortunately.
It’s still possible someone messed up the bmc firmware.
So re-flashing can’t hurt.
This zip file comes with 2 firmware images in the fw folder.
They are both the same firmware but the one called rom.ima_enc includes a secondary process to restore the bmc to factory condition.
No need to use the update scripts in the zip, installing from the ipmi web console if fully supported.
I’ll link a manual you can follow completely except for step 4, you want to uncheck all boxes relating to preserving the old config https://www.gigabyte.com/Support/Security/1766
When the update is done and you reach step 10, use the full flush option.
Don’t worry about the boot version if empty or 0.0.
It gets rebuild when all post checks are done and the bios loads.
If you still mis sensors, repeat the things we just did with the 126139.bin file.
rom.ima_enc should have been the correct one, but who know I missed something or gigabyte mislabeled them.
I already cleared the BMC after updating it, and set the BIOS back to factory defaults before working on it. I did get a reply from Gigabyte, the “G” indicates grouped sensor readings. So I guess M2_G0_AMB_TEMP is the average of the two m.2 sensors, and the DIMMG0 and DIMMG1 readings are the averages of the two groups of DIMMs (A/B/C/D, and E/F/G/H I assume).
Those readings are profoundly useless for identifying individual overheating components. Ugh.
I see, they have a really barebone BMC setup as I’m able to see individual ram temps and whatnot on my Supermicro board.
There still should be basic sensors data available like on every motherboard your OS can access.
It’s not unusual in the IT to have the OS and BMC both send sensor data to a common log server to allow for more comprehensive monitoring.
But sucks you have to make it all yourself.
