Gigabyte MC12-LE0
I just tested mine. CPU is required (I used 5650G) and I had one stick of RAM in slot A1.
The IP of Managment I got out of my fritzbox (you neet to connect the managment port with your network first).
Connecting to the IP required the password (on the box or the mainboard itself). The System was powered on for the follwing process.
Under Maintenance>Firmware Update I uploaded the image.RBU of from the Gigibyte Update files. After that I selected “BIOS Update” and the flash was successfull.
BUT it did not show immediate success (“System Inventory” still was wrong), firstly I powered the system off via “Power Control” and gave it some time. After that i powered it on again via “Power Control” and the “System Inventory” did no longer show the dummy entries, but my correct CPU and Ram.
The BMC I did not try to update yet.
Ok so i got one of the boards working, but the other did not cooperate, so i send it back.
For me it was important to:
  • have only one RAM-Stick in slot A1 (Not A0!)
  • have a updated BMC
  • have a CPU installed
  • have the board be turned on
Hope this helps someone.
I can confirm that it works if done as described by @annoxedcustomer, but I had to use an 8GB stick in slot A1, it didn’t work with a 16GB stick.
I also had to turn sync off and on again in the web interface, but then it worked and the System-Inventory showed the right parts.
I hope this works for others as well, because than these boards are an amazing value since they can be had for 40-50€ new.
If anyone knows a way to enable sleep on those server-boards, I would be grateful.
I have a 5700G installed and no matter where I put my 16 or 32GB ram, and when logging into the web interface I only see 4GB of ram and the board identifies my cpu as a 3600.
I want to give an update to this thread. I have one MC12-LE0 in combination with an AMD Ryzen 5 3600 as well as one stick of 16GB 3200MTs ECC UDIMM in slot A1. This combination works fine, the firmware and BIOS version were old, but I could update both in the BMC web interface. As long as the board does not break I will be happy with it.
So this needs a BIOS update to work with, say, a Ryzen 9 5900 12C?
