I just had a look into my Mainboard’s BIOS LLC settings and the following are availabe:
- Auto
- Standard
- Normal
- Low
- Medium
- High
- Turbo
- Ultra
- Extreme
Any idea on what to chose or what those values mean? Personally, I would like to optimise forol longevity, so Medium should be fitting (??), but currently it is set to Auto. Also, any idea what Standard and Normal do/are?
Furthermore, Project Hydra and CTR recommend High setting for Gigabyte boards I don’t want to kust copy that settings.
The board I’m talking about is the X570 Aorus Master rev.1.2 if that helps.
Any answer would be appreciated!
