Gigabyte GA-H97-D3H: Optane not recognized as boot drive but installation worked
Hello Level1Techs Forum.
For transparency: I already posted it in the LTT Forum with minimal success.
Maybe here is the better suited place for my problem:
After the current NVME boot SSD of my Proxmox node died, I wanted to try an Optane M10 32GB as a replacement.
The installation of proxmox ve 8.4 from usb worked without problems. (I know its not the latest proxmox version, but that is the current running version in the cluster)
But after rebooting and removing the USB stick it just lands in the BIOS with the warning no boot device detected. The drive is also not visible in any BIOS entry.
The System:
  • Motherboard: Gigabyte GA-H97-D3H updated to latest BIOS version F7
  • CPU: Intel Xeon 1231 V3
  • RAM: 32GB
  • PSU: bequiet Straight Power 10 500W
  • GPU: AMD R9 290 (only for display out during installation)
  • SSD: Intel Optane M10 32GB MEMPEK1J032GAH
  • SSD: Lexar NM620 1TB (previous/dead)
What I already tried:
  • Using onboard m.2 and pcie to m.2 adapter (previous SSD has worked in both)
  • Setting BIOS options where possible to UEFI first/only
  • SSD with adapter in a similar old system → also no boot device detected
  • SSD with adapter in newer/current system → drive recognized in BIOS and bootable
So the installation is working and shows the drive. The already installed drive moved to a modern system is booting. Only in the target system and a similar old system the drive is not seen as a boot device.
I suspect either some wrong configuration in the BIOS (but the previous NVME SSD has already worked) or some weird behavior of optane on older systems, but why is it showing up and working while installing?
Thanks for your help in advance <3
optane uses a weird 2x2x and you need motherboards that support it, Idk if it’ll work in something as old as haswell
That was only the NAND hybrid H series Optanes that had the weird 2x2 bifurcation setup.
Im assuming the boards uefi has some quirks that dont make it recognize that ssd for some reason.
Since linux detects it fine as you can install proxmox on it, you can probably work around the issue by placing the boot partition on a small usb drive.
This way the motherboard boots from usb, which works fine
See Make Proxmox VE boot with USB · GitHub
Interesting idea to boot from usb. I will try that.
In the meantime I already recovered the node with a hdd as boot from my backups. So either way its up and running again. And Optane will latest come to use when I do a platform upgrade to something more modern.
