with the GIGABYTE B450 AORUS PRO Wi-Fi
can this mobo run two PCIe Gen3 M.2 NVME drives at full speed an a a sata 3 seagate 10td hd an a blu-ray burner IM i reading the specs right ?
an is this mobo a better overclocker then the aorus b450m
also pardon another noob question from me iv got a
ASRock B450M Pro4 Micro that going into a separate build will it be able to run two nvme drives at the same time just with one at a slower speed or would i be better served getting two of the
GIGABYTE B450 AORUS PRO Wi-Fi mobo’s
my current build that im running on is a aorus b450m that only has one nvme slot im running a 2nd nvme off a pci express x8 expansion card but it doesnt work so well
every boot i have to refresh the drive mount va the drive management window before use this is very annoying so i figure two actual nvme slot would fix this even if one runs slower
