I looked up a while ago on the "Maxwell" architecture to replace the already fine Kepler based GPU's, why do we "need" this? Is it worth it? Or is it just another Concorde idea.
It'll definitely be interesting to see what the additional ARM processor on the cards will do performance-wise. It's supposed to make it easier to program for the cards as well. On the other hand, they're also talking about bringing down power consumption, which is always welcome in my book.
Of course, we can't say anything for sure until we have the cards to test, but it looks like it could be pretty interesting.
I hope Nvidia is more Generous with the VRAM count. 3gigs may not be enough anymore if 4K Kicks off in about 2 years.
(sorry if there is italic) I suppose less power consumption may equal less heat creating more possibilitiesfor more VRAM and such although I don't really believe that 4k will necessarily be a consumer product unless its a home theatre or workstation monitor, however with the arrival of G-Sync I'm looking forward to the hopefully near future
Yes but performance always takes a hit when they try to bring power consumption down. It's hard to balance the two.
I don't like the GTX 760 and GTX 770 having only 2gb / 4gb options.
4gb is more than enough for either of them to play at 1080p whilst if used for playing at higher resolutions it wouldn't make sense anymore to go with a gtx 760.
When they do increase the VRAM, I hope they won't do the same thing again for what will be next gen's requirements. Like.. 3GB/6GB while what we really want is GTX 860 with 4GB. If you know what I mean, make something that makes sense to buy. Like how today a GTX 770 with 3gb would be perfect for everything I need but it doesn't exist.
