So based off a couple opinions this is what i have gotten. Is there any way to get the same performance cheaper or maybe better performace for the same or cheaper?
This is it and its right at my budget cap http://pcpartpicker.com/p/twhg
Thanks, Zach
Thanks, Zach
Well first off, you're getting a liquid cooler for a locked processor lol
Change that to a i5-3570"k"
You can also shave about 30$ off of the ram and change that heatsink with a Hyper 212 and still get very nice performance for a lot cheaper, and use that extra 100 something dollars to get a better video card like a 7950, and it will perform better.
I would go with the 2500k its a little cheeper and it can be over clocked, other wise it looks good.
And that is why I post haha because I don't really no now exactly what all that mean but thanks ill change it up I'm just trying to get a full setup computer oan monitor keyboard and mouse for 1000-1100
hmm nice looking rig you got there, i would recommend going up to a 3570k it's only 5-10 bucks more expensive, and you can't overclock with the non-k version. And if you're not going to overclock then there is no point to go with the h100. If your not overclocking then go with a cooler master 212 evo and but the extra money into the video card
Intel 3570k
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
Cooler master 212 evo
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
I'll make you a nice build on pc part picker right now for you, without a monitor and stuff though.
Alright well thanks to both of you
http://pcpartpicker.com/p/twv2
Here you go, a little bit cheaper, should run better though.
http://pcpartpicker.com/p/twCC This is still in you budget and is a soild proformer.
Word thanks twitches I think is more for me because its what I originally wanted and I still am able to do everything for it little less
Probably wanna swap out the rosewill PSU with something more trusted but that's just my paranoia. For all intents and purposes, it should be fine.
