I want to buld a gaming PC that will run ARMA 2 on Medium Settings for around 500 hundred dollars for everything including the OS!! Here are the Specs: (Parts on Newegg.com)
Case - NZXT LEXA S LEXS - 001BK Black Steel ATX Mid Tower Computer Case - $80
MotherBoard - ASRock 970 EXTREME3 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard - $85
GPU - SAPPHIRE Vapor-X 100358VXL Radeon HD 7770 GHz Edition 1GB 128-bit - $140
CPU - AMD Phenom II X4 965 Black Edition - $85
RAM - G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 - $40
Power Supply - CORSAIR TX Series CMPSU-750TX 750W - $130
HDD - Seagate Barracuda ST1000DM003 1TB 7200 RPM 64MB Cache - $70
DVD Drive - ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM - $20
OS - Windows 7 - $100
Tota on Neweggl: $750
I know this will probalby not happen but i really want to keep it under 500 dollars.
Also this is my first build so i am going to start out low
Please help because the main reason i want to get into PC Gaming is to play DayZ and if one you guys has a 500 dollar PC and can run DAYZ on medium settings, please help!!
