Hey All,
I’m looking to move my water cooled gaming PC to a rackmount case. The current box is sitting inside of a server cabinet (Open door, but is closed on 2 sides) and doesn’t breathe too well. The side panel is off and doesn’t fit with the GPU. It’s basically running open frame.
The build:
- O11 Dynamic Razer edition with Front panel reservoir + D5 pump
- MSI ATX board
- i5-13600k @ 5.6GHz with water block. Draws about 150W at peak
- 32GB standard height RAM
- 2x M.2 SSDs (No 2.5 or 3.5")
- Corsair HX1000 PSU
- EVGA RTX 3080 Ti Hydro series OC’d and draws around 460W at peak according to HWMonitor. It’s set at +120 at core and +1215 in memory
- Dual 10Gb SFP+ network card
- 2x 360mm radiators with fans in push
- Has 9 fans in total running about 75% or 100% in longer gaming sessions
I found the Silverstone RM52 that seems to fit the bill, but I’m looking to see what other options are out there before I buy. I have plenty of rack space so I won’t have a problem with space. I would say no more than $500 for the case and I do run them until they actually fall apart typically. I had a Fractal Define XL R2 before the O11.
Other concerns I could use advice on:
- Suggestions for a reservoir or a pump/res combo that fits a D5 or DDC. I have 1 of each, but would prefer to keep using the D5. I think either a short pump/res housing behind one of the radiators may work, or the EK flat res 120. I would have to sacrifice an exhaust for that.
- Any coolant alternative to Mayhems M1 that works just as well? I run without dyes and I’m also considering switching the tubing to the zero maintenance tubing. I know some brands are a reseller but I forget who.
Thanks All!
