Being required to use your sense of smell when troubleshooting almost never turns out well…
Was it like the guy posted
About the power?
A warning for those not in the know
Be sure to check if your Tesla uses EPS 8 pin CPU or PCI-E before plugging in
Heres the damage…
Under this cap… is this…
I must have missed that post… worked fine on my grid…might be because of the age of my Dell Server is only supposed to be used with certain cards.
Maybe it died open and prevented further damage
It’s pretty close to the input so maybe there’s hope
Tweet at buildzoid
Will do sir. Not a huge deal. Im sure i can figure it out. I dont have tweet, but can try reddit.
Looks like 10 points… not sure i can fix that but maybe… I’ll try with my dad once I figure out the part I need.
TO EVERYONE: THIS IS ENTIRELY MY FAULT BEING A NOOB…lol
I’m going to have a drink…
I found the adapter cable in the BOX! I cant believe I did this…
They say you’re not really a doctor until you’ve killed a patient.
Now you’re a GPU doctor.
I want to say maybe I can fix it but my soldering skills need some work before I’d attempt it
Im going to try anyways. See what my padre says. Hes done this stuff for ages. I just need to identify the part… its something to attempt for the heck of it. I’ll document it. I always wondered if I could fix some of those broke cards for cheap on ebay…lol
I’ll take a picture when I get home of my M40
No worries at all. Its a pain to remove the whole back cover. I wouldn’t worry about it. May write it off as a learning experience…
I’m terrible at soldering but one tip that helps me is to do it first thing in the morning before you have any caffeine.
That’s what got me in this mess lol I only had one cup and brain was a little fuzzy
Showed Wendell, we’re gonna pop apart my M40 to see what that chip is to see if it’s doable
Only if you have time and nothing else to do lol. No worries really it was sooooooo my fault.
I could probably do each leg with a solder sucker, but if its multilayered theres a chance of burning up the etchings in other layers if I’m not careful… I may try just for fun if I find a good part.
