No I just got server fans for free
I like free! ![]()
Hello!
So I’ve been able to get the Tesla P4 chugging along, but I feel like I’ve been getting some performance issues, I get alot of dips and dropped frames (Heaven benchmark had a good average fps, but looked really choppy with the frame rate dropping to 18.6 fps).
All I have installed are the grid drivers and I was wondering do I need any geforce drivers installed for gaming?
Another thing I noticed is i440fx gives a 2k better score on OpenCl for Geekbench that Q35 and I don’t have ReBar enabled. GPU-Z says I have 4g enabled and CSM disabled, but says the Tesla P4 is an “unsupported GPU”. In my main bios (not vm bios) I have 4g enabled and I am quite sure CSM is disabled.
There is no option in my bare metal bios to enable ReBar (Asus P10s-M-WS) I was wondering if anyone had any advice for trying to move forward?
I am getting about 30k in Geekbench 6 OpenCl (I am not sure if this what I should be getting).
I looked at three of my cards M40, P40, and P100 with CPUZ and they all say unsupported like in your screenshot. Here is a SS of my GTX 1660 not sure if it be of any help, but you could be seeing a bottleneck of some sort. Perhaps CPU or something running in the background or the display out card.
Edit: I found this while searching for something else it might help you with why Resizeable Bar isn’t working or an option.
What display GPU are you using
So I ran the benchmark and got a similar score to you (as I feel it’s a bit disheartening as I thought this gpu performed as a “1080 lite”). It didn’t go above 70c (so I don’t think it’s thermal throttling).
I did see that reddit thread and when I was turning on my 4g in my bios, looked around for the rebar option and didn’t see it anywhere. The last bios update for this mb was '18-'19, so maybe it’s not there?
Maybe it’s something in the bios menu of the virtualized bios (Q35 or i440fx) as this is a VM running under an Unraid Hypervisor.
Maybe it’s the CPU also… I have a Xeon 1245v6 which I’ve passed through 3 cores and their respective hyper threads (while keep the 1st core and ht reserved for the Unraid OS). I thought it would be enough cpu, but maybe not? Also maybe passing through wasn’t enough, maybe I need to isolate the core for the vm. If that is the case, maybe split 2/2 cores… hopefully 2 cores at 3.70 ghz would be enough to game on? (I am hoping to play Diablo 4 & Baudur’s Gate 3).
Welp…
I don’t have a display GPU, this is a gaming VM. I did try to push through the igpu from Unraid but it wasn’t happy. I don’t have Parsec Warp so couldn’t use their vGPU driver.
I tried using the Tesla’s vGPU monitor thing (Its called Nvidia VGX Monitor) in my system under monitors) but it was limited to 768p resolution (there was no way I could figure out to force a higher resolution). I ended up assuming this was a limitation on the gpu by Nvidia as I’ve gotten it to work with the grid drivers, but I don’t have a license for it.
So I stumbled across a reddit post where some used something called USB Mobile Monitor Virtual Display, which I was able to get to work, but also now seeing the Heaven Benchmark above, it might be limiting the Vram to 4gb, might be causing issues also? Ugh, I feel like I am falling down a rabbit hole inside another rabbit hole…
Well its power limit is about a third and the clock is about half and it only has gdddr5 and not 5x
Pascal really likes being cold so maybe you can make it cooler to boost clocks
If you use a powered riser that can deliver sufficient poweryou can try shunt modding it to raise the power limit but I wouldn’t go too much past it
So I did get it pretty cold with the fan setup (at 100% it doesn’t go over 70c and is about 35-40c at idle) and did overclock the the clock to 1531 MHz (it yelled at me for anything above) and memory to 3003 MHz (at least according to MSI Afterburner, GPUz says its 1499 MHz when I hit it with 100%).
Ugh, didn’t realize how much power difference there was (which makes sense because it’s just coming from the slot). Maybe this is how much performance to expect out of this then…
I would say try it bare metal install first to see the true difference, nice to see it overclocked I’ve heard the p40 and p100 don’t
Unfortunately, I don’t have a machine I can bare metal it in (all I have is the Unraid server, trying to make it a gaming vm as my only other computer is MacBook m1, and blizzard didn’t release d4 for Macs).
However, I did find something interesting, apparently there is a limitation with using grid drivers as a direct single display monitor, but not for doing it as a vm (which I think thats was Craft Computing did with their proxmox setup). But it seems like there isn’t this limitation with the Quadro vDWS drivers or vCS drivers (or license) - so uhhh maybe there is something there…
Maybe I should’ve gone for Quadro drivers instead of Grid…? (I have no idea what I am doing).
Ok - I might have hit my limit, this is a rabbit hole inception going on right now looking at different drivers and licenses. I think at this point I am gaming at 768p (which I guess is kinda what the steam deck does anyways), ok with the lag/stuttering or pony up for a gpu that fits my needs a bit more. At the very least it seems to be working well with AI modeling stuff (I scanned a whole bunch of photos and film my parents had when they were younger, and want to use AI models to correct and upscale automatically, so I don’t have to use it manually). I will put the Tesla GPU to good use, but alas prolly not for gaming (or at least much gaming)…
This is odd I swapped cards around in this same PC and the K40m out did the 1660 so maybe it was the driver used with 1660 or something else lower its scores. I thought they looked low but what the hell? lol
Not sure this is the best place for this or if its been posted already, but here is something of intrest I just found.
(omg)vflash | Fully Patched nvflash from X to Ada Lovelace [v5.780]
Now that pascal bios has been opened up a P4 and P40 are my next cards I want
If anyone is curious, titan Xp is way faster than X pascal
What does this potentially mean for a theoretical ‘p4’ owner (the bios being opened up)? What can one do with a modified bios?
Not sure exactly you can set your overclock at bios level so the card thinks those are it’s stock clocks so it’ll boot like that
It’ll let you set whatever voltage you want as well
Power limit is still probably a hard limit since that’s the pci-e spec
Not sure if it is by design but after monitoring my P4 for a while it seems like it normaly uses 41W when running Stable diffusion, except for once in a while spike on 69W. But it’s not in the beginning of a render or something like so I’m not sure if it is part of use, or part of preventing people from overclocking it.
I think there’s a bunch of set up stuff in the beginning in SD, you might be voltage limited if it’s not clocking higher during the less demanding parts
Have you had any luck getting any of your pascal gen teslas to flash any none Tesla firmware? bc I have not.
