Gaming mouse for £30/$50?
hi guys, want to know your opinion on what gaming mouse to get for around $50!
logitech g400, g500.   CM storm spawn/xornet
http://www.amazon.com/SteelSeries-Call-Black-Gaming-Mouse/dp/B009OYUFMG/ref=sr_1_4?ie=UTF8&qid=1378602161&sr=8-4&keywords=gaming+mouse
http://www.amazon.com/SteelSeries-Kinzu-Optical-Gaming-Mouse/dp/B007B5V1PU/ref=sr_1_10?ie=UTF8&qid=1378602161&sr=8-10&keywords=gaming+mouse
http://www.amazon.com/Corsair-Raptor-Gaming-Mouse-CH-9000042-NA/dp/B00CXI0BAG/ref=sr_1_15?ie=UTF8&qid=1378602175&sr=8-15&keywords=gaming+mouse
http://www.amazon.com/Logitech-Gaming-Programmable-Controls-910-002358/dp/B005EWB3AU/ref=sr_1_5?ie=UTF8&qid=1378602191&sr=8-5&keywords=gaming+mouse
http://www.amazon.com/Razer-Abyssus-Optical-Gaming-Mouse/dp/B002XLR0JI/ref=sr_1_2?ie=UTF8&qid=1378602202&sr=8-2&keywords=gaming+mouse
Go to the nearest store and try some out. What might be great for some can be awkwardly uncomfortable for others.
i will check them out!
cheers for the links
yeah ok that makes lots of sense. thanks!
well its about £35 on www.scan.co.uk but i have the cyborg rat 3 its wired got a pretty decent laser and dpi. it also has three different profiles, two programable buttons and a dpi switch button. so pretty good for the price and its seriously comfy for me who has pretty big hands and uses a palm grip for gaming :)
I bought my G600 (one of the best) for $61. Def worth looking at.
Not a fan of the overall feel or the ring click. Just a question what do you even map to your ring click?
I map the DPI shift so I can really aim well.
If you're looking for sensor quality/performance, I'd look at some Zowie mice. You might be able to snag an AM for $40 if you look close enough. If you have a really small budget, another great choice is the wheel mouse optical ($10)
