Looking to stay below $700. From reading a little more about the monitor it seems this is the one that will eventually have G-sync installed. I might just wait until I can get the G-Sync version.
Monitor Looks fine. But if you wait for the G-sync version make sure it will support Displayport 1.3 because DP 1.3 will be compatible with Freesync, and you never know when you are going to change the computer ( it always happens to me that monitors last more than GPUs. http://www.pcper.com/reviews/Graphics-Cards/AMD-Variable-Refresh-FreeSync-Could-Be-Alternative-NVIDIA-G-Sync
