Gaming Monitor
What is the best monitor for playing games on? Preferabley around 24"  but if a bigger one is great then I am fine with it
Asus VG248QE or BenQ XL2420TE  Use them with lightboost and you will be set they have almost zero motion blur.  Otherwise get an IPS like the Dell 2312hm
Highly recommend the Asus VG248QE.  With the lightboost hack the responsiveness is simply amazing.  BlurBusters is a goldmine of info, making the lightboost pretty straightforward to enable.
