Hey all,
Just thought I’d share if helpful to anyone. Before I continue, yes I’m gutted that I’ve chosen Shelly as they’ve recently been bought by a bigger company that will strip it of all decent features. At least in theory, it could be used offline if needed via Home Assistant.
My house is old, so there’s no heating in the kitchen because ‘back in the day’ there would always be heat from cooking. These days with air fryers etc, there’s less surplus heat being used to heat the room, so it’s cold. I’ve thought about adding radiators but the routing is a pain, limited by cupboards and distance from switch/pump.
So against my preferences, I’m switching to electric heating ‘temporarily’. I’ve got a plinth heater that can run at 1KW because I don’t want to overload the circuit more than I have to - we have the usual toasters, dish washer, washing machine, microwave that already takes the circuit to the limit. At some point I’m intending to extend an unused fuse to other areas, potentially including the new kitchen heater and moving the washing machine to another room/circuit.
The back of the kitchen near the back door is the coldest, so that’s where the plinth heater is going. Because I have smaller humans that leave doors open all the time, it needed to turn off when the door is open. I also don’t want it running all the time, so the principle is:
- Turn on during a specific part of the day when the temp is below a set temperature.
- And Turn off when the door is open for x minutes/seconds.
- Or Turn off when the circuit exceeds X watts
- Turn back on when the circuit usage is low enough and the door is shut.
I bought these…kicking myself I did so BEFORE Black Friday ![]()
Onto the Shelly system I created scenes - sadly I did have to turn to AI because it’s not entirely intuitive…for me at least! ![]()
These are just test settings that I’ve set up in my office, because I can easily exceed a KW of usage - saves me having to turn the toaster on, I can just turn on my office heater instead (Using stuff I bought from mylocalbytes, who tragically have stock issues all the time).
You can see that a lot of settings still need some tweaks, like the active time, delays, etc. and many other things, but it’s working well.
Hope that helps someone ![]()
