Would you guys suggest this in a system witha 8350?
if not please throw some suggestions my way thanks !
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2941929&CatId=7387
forgot this haha
For gaming? Certainly not. Not only is it massivly overpriced, you should be spending at least twice as much on your GPU as your CPU.
My build:
8350
gigabyte 7970
noctua nh-d14
asus m5a99fx
antec 850w gold power supply (in case I buy another 7970)
nzxt phantom 820
samsung 830 128gb ssd
WD caviar blue 1 tb hdd
maxes out any modern game at 1080p
would this do ? http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=7876675&CatId=7387
What exactly will you be using the system for, and what is your total budget?
Just get the 7870 or 7850. Save up for it so that it can be a long term card. I personally think the 650 Ti BOOST is a fail. Save up, in the end it's highly worth the wait.
FX 8350
Asus Sabertooth 990fx
GTX 670
Cooler Master Hyper 212 Evo
Cooler Master GX 750
NZXT tempest 410
Muskin Redline 8gb
good stuff like that :)
FX 8350 with custom liquid cooling made by myself.
G.Skill Ares 8GB 2x4
GA-990FXA-UD3 (great board)
Samsung 840 120gb
Radeon 5850 (going to go for a tahiti le 7870 when the 8000 series comes out.)
That's my build and I love it to death. The processor is great.
did anyone that has a 8350 have trouble with the cpu not going in in the gold triangle corner ?
