I was set on the i5, only question was wheter to go ivy or haswell. But lately i've been seeing the FX 8350 get mentioned everywhere. So I'm not really sure anymore.
The CPU will be pared with a GTX 760 and it will be used for gaming and generall usage. I'll get into overclocking eventually.
I'm on a bit of a budget but it's set around the 3570K so going 4770K would be a bit of a strain, but if it's worth it than i think i can cram it in there.
Hmm.. I don't really save any money since the AM+ boards are more expensive than the ones compatible with the i5. I'll have to think about it, thanks guys!
